Thread: Weird starting issues
Results 1 to 4 of 4
  1. #1 Weird starting issues
    SE Level Member Ophidia's Avatar
    Nov 2010
    West Fargo, ND
    I just bought an 04 GP GT. Almost immediately after I signed the papers, it started having starting issues. What it does is spin the motor just fine with the starter, but just fire a little and miss then die. If I hit the throttle at just the right time, it'll start. I thought maybe the battery had some lot rot, but charging it had no effect. I'm not sure where to go from here. Ordinarily I'd say IAC but this looks to be drive by wire so no IAC. Once started it runs just fine.
    Ideas?
  2. #2 Re: Weird starting issues
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    My '04 was doing the same thing. I just went out and bought some MAF sensor cleaner and throttle body cleaner and cleaned the piss out of it(pitch black stuff came out of my throttle body for a good 15 minutes). But after that it starts just fine!
  3. #3 Re: Weird starting issues
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    Quote Originally Posted by Vlad0691 View Post
    I had the same problem for the longest time, I nuked by throttlebody and so far haven't had the problem since.
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  4. #4 Re: Weird starting issues
    Jun 2010
    michigan
    X3 on cleaning the throttle body. $5 can of cleaner..10-15 minutes and haven't had the issue since.
  1. Starting issues
    By Billyb in forum General Tech Discussion
    Last Post: 12-21-2016, 12:27 AM
  2. Car Starting Issues!
    By Cal Cross in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2010, 12:44 PM
  3. starting issues
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 12:18 PM
  4. starting up issues / gas???
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2009, 08:42 PM
  5. Starting Issues
    By BigBird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2009, 12:22 PM
