Thread: Cylinder #2 misfire
Results 1 to 14 of 14
  1. #1 Cylinder #2 misfire
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    As the title states, my car is misfiring on cylinder #2. The misfire occurs right after startup (doesn't matter whether is a cold start or not). It will miss for about a mile or so of driving and then, like a lightswitch, it goes away. It will do this every time I start it. Here is a list of some things that have been checked/replaced already.
    Plugs
    ICM
    PCM
    Plug wires
    Coils
    Injectors
    Seafoamed
    Any ideas on what could be causing this?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: Cylinder #2 misfire
    St. Louis
    Sticky valve maybe? Might try running some Seafoam with the oil about 100mi. before your next change and then see what you get after changing the oil.
    Is there any tapping associated with this miss? The only other thing that comes to mind is a lifter is bleeding down after shutdown and needs to be pumped back up everytime you fire it back up.
  3. #3 Re: Cylinder #2 misfire
    Newnan, GA
    I don't hear any tapping sounds, just your usual misfire.
    I will try the seafoam as I know the car could use it elsewhere as well.
  4. #4 Re: Cylinder #2 misfire
    Newnan, GA
    Seafoam didn't fix it. Any other ideas?
  5. #5 Re: Cylinder #2 misfire
    PA
    What plugs are you running? What gap?
    2001 GSE
  6. #6 Re: Cylinder #2 misfire
    Newnan, GA
    ^stock replacements, or equivalent. The shop put them in.
  7. #7 Re: Cylinder #2 misfire
    PA
    Quote Originally Posted by EJOUIE View Post
    So a shop has been doing the work, not yourself?
    2001 GSE
  8. #8 Re: Cylinder #2 misfire
    ect sensor?
  9. #9 Re: Cylinder #2 misfire
    Newnan, GA
    Quote Originally Posted by Zef_66 View Post
    My parents own the car and they don't trust me working on it, so I take it to a local shop and we work together on it.
    Anyways, the shop just called and said its working now. They ran the cleaner again and changed 2 plugs. Seems weird to me that this would have fixed it...I have a strange feeling that the problem decided to go away on its own just as mysteriously as it arrived and has a good chance of returning.
  10. #10 Re: Cylinder #2 misfire
    PA
    They changed two plugs. I would be that is where the problem was. Either gapped wrong or cracked them.
    2001 GSE
  11. #11 Re: Cylinder #2 misfire
    Newnan, GA
    That could be it, but this is the third time within 6,000 miles that my car has had to have some plugs replaced. Every 1,500 miles or so a new misfire condition seems to arise which could mean
    A) I am unlucky and 3 unrelated misfire events took place
    or
    B) underlying problem that is causing the plugs to die prematurely.
  12. #12 Re: Cylinder #2 misfire
    If only we could see what they look like after 6000 miles.
  13. #13 Re: Cylinder #2 misfire
    PA
    Agree with matt. If they plugs are smashed, then you have a deeper problem. Ask the shop what the plugs look like when they replace them.
    2001 GSE
  14. #14 Re: Cylinder #2 misfire
    Newnan, GA
    When it happens again I will make sure to get a picture of the plugs, so I will keep this thread on hold until I have more information.
  1. Misfire in Cylinder 5
    By 06gtSC in forum General Tech Discussion
    Last Post: 04-19-2011, 03:50 PM
  2. Possible cylinder misfire
    By TopGunSalo in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-03-2010, 02:57 AM
  3. Cylinder Misfire!
    By AFBCamaro in forum Introductions/Noob Questions
    Last Post: 05-01-2010, 09:52 PM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
