Thread: changing back 3 plugs
Results 1 to 10 of 10
  1. #1 changing back 3 plugs
    Jun 2011
    detroit
    can any one give me any tips on changing the back 3 plugs
  2. #2 Re: changing back 3 plugs
    Waukesha, WI
    rock the motor foward
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: changing back 3 plugs
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    There are quite a few threads for this already.
    Remove the two bolts on the top front mounts and tie the engine forward.
  4. #4 Re: changing back 3 plugs
    SE Level Member 1fastgtp's Avatar
    Jun 2011
    Lewiston
    Remove the two fonr bolts to the dog bones (motor mounts) soo they way they are only connected to the engine, then get some rachet or tie straps and put that motor forward as much as you can, that should give you enough room. If you still need help use the search button.
    2000 Grand Prix GTP: Modifications: SLP catback exhaust-SLP Headers- 180 Termostat- wizaired cold air intake-PRJ 10.4mm wires- autolite 104's- zzp tune- full size intercooler- vs cam- 3.0" pulley ETC. Fastest Grocery Gitter in town
  5. #5 Re: changing back 3 plugs
    Jun 2011
    detroit
    ok thanks
  6. #6 Re: changing back 3 plugs
    Jun 2011
    Lewiston
    np and good luck.
  7. #7 Re: changing back 3 plugs
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    reach back there and change them. Im 6ft 2 250lbs and I can fit my arms back there to change mine.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: changing back 3 plugs
    Waukesha, WI
    do you have a strut tower bar on your car?
    RayRay
    92 Turbo miata
    02 lexus is300
  9. #9 Re: changing back 3 plugs
    if you put it in reverse then you dont need to pull it, it moves for you
    SMGPFC Member #10
  10. #10 Re: changing back 3 plugs
    Mullet Member Wotgtp's Avatar
    Connecticut
    I have no problem just reaching back there and changing them.
  1. Changing plugs. Cant get the wires unplugged.
    By Wakeboy1337 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 12:52 PM
  2. Changing Freeze Plugs
    By tmackster in forum General Tech Discussion
    Last Post: 02-06-2011, 11:44 PM
  3. Changing Spark Plugs on a 2004 Grand Prix
    By Clarkie59 in forum General Tech Discussion
    Last Post: 01-29-2011, 11:23 AM
  4. Changing Back Spark Plugs
    By Badbird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2009, 07:24 PM
  5. Changing the Spark plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:24 AM
