Thread: No power on acceleration when up to temp.
Results 1 to 20 of 24
  1. #1 No power on acceleration when up to temp.
    Dec 2010
    Keene, NH
    I have a 97 GP 3.8. When the engine is cold is has all kinds of power but when it gets up to temp, there is hardly any power at all. You have to just about floor it to get it moving. I have a vacuum gauge and its reading 20, I believe thats normal. There is probably a thread already for this but I couldn't find anything. Any help is appreciated. Thanks
  2. #2 Re: No power on acceleration when up to temp.
    Kansas
    Supercharged or N/A?
  3. #3 Re: No power on acceleration when up to temp.
    Dec 2010
    Keene, NH
    Sorry, N/A
  4. #4 Re: No power on acceleration when up to temp.
    How old are your plugs and wires.
    If you have power cold, that means your getting knock. Reason it works cold is the knock sensors aren't used until the car gets to abotu 160F
  5. #5 Re: No power on acceleration when up to temp.
    Kansas
    Stock?
  6. #6 Re: No power on acceleration when up to temp.
    Aaron..you can ask more than one question per post. Bio is unable to post..you'll catch him soon..lol
  7. #7 Re: No power on acceleration when up to temp.
    Kansas
    Nah... can't catch this... I'm N/A.... lol.
  8. #8 Re: No power on acceleration when up to temp.
    Could be a clogged cat as well.
    Any check engine lights?
  9. #9 Re: No power on acceleration when up to temp.
    Dec 2010
    Keene, NH
    I don't have any codes and I just replaced the plugs and wires about a month ago cus I had a real bad missfire. Thats gone now and the motor is all stock
  10. #10 Re: No power on acceleration when up to temp.
    Got a scanner? I'd put money on this being KR.
    Check that your #4 and #6 plug wires didn't hit and melt on the O2 and aren't touching the O2 wiring.
  11. #11 Re: No power on acceleration when up to temp.
    Dec 2010
    Keene, NH
    I have a scanner and yesterday I hooked it up and looked at everything and my scanner shows timing advance and it read (-) a number and the more I accelerated it decreased the timing up to 40. I'll go check the wires
  12. #12 Re: No power on acceleration when up to temp.
    Dec 2010
    Keene, NH
    #6 Plug wire is touching the o2 sensor. Would that affect it?
  13. #13 Re: No power on acceleration when up to temp.
    Kansas
    Quote Originally Posted by ABeam View Post
    Yep.... The wire can "arc" as its firing the cylinder and can cause a faulty signal to the o2 sensor.
  14. #14 Re: No power on acceleration when up to temp.
    Dec 2010
    Keene, NH
    Ok, It kinda makes sense but could that cause up to 40 degrees of timing retard. There has to be something else causing it I would think.
  15. #15 Re: No power on acceleration when up to temp.
  16. #16 Re: No power on acceleration when up to temp.
    Jun 2011
    Tampa, FL
    Same problem here with same engine. when the problem started a month ago I but in a new cat, both ox. sensors, all new plugs & wires, and new injectors just today. I dropped the fuel tank and cleaned out some rust w/ acid. I inspected and cleaned the fuel pump at the same time (its one year old). Nothing looke melted. When engine warms up, it cannot wind out more than 2100 RPM, this decreases until the limit is about 1,200 RPM and max speed at this point is about 15 MPH. Runs fine when cold and wrming up, and idles fine too.
  17. #17 Re: No power on acceleration when up to temp.
    Dec 2010
    Keene, NH
    Thats pretty much what my car does to griffin. Could that cat still be clogged in my vacuum gauge is reading normal-around 20? And would it not have power all the time cold or hot if the cat was clogged? thats what I thought but could be wrong
  18. #18 Re: No power on acceleration when up to temp.
    Is it required that I'm rude for you to listen to me? If you'd like I can be a total ahole and while it'll get me plenty of likes, it's not really my preferred style.
    I suggested wires on the O2 because I'm a retard and was guessing wildly in the air, definately wasn't experience.
    I also said you had KR, because I explained goes on and why it does.
    So would you rather I write like the above, leave your thread alone or help you solve the issues in a nice manner? Because.. yes... very likely I know the solution. It's just a matter of you answering the right questions for us to solve this and your car will be a happy camper again.
  19. #19 Re: No power on acceleration when up to temp.
    Dec 2010
    Keene, NH
    I have answered your questions but I will once again. #4 wire wasn't touching anything but like I said #6 wire was touching the o2. I pulled the wire away from the o2 and still have the same problem. What I don't understand is how I'm getting KR
  20. #20 Re: No power on acceleration when up to temp.
    You mention you scanned timing. How about KR?
    What plugs did you put in? Looking for brand and type, for example Bosch double platinum.
    What brand of wires?
    Which..is about the most common issue in our cars.
  1. update: no power on acceleration
    By jrmac88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-13-2011, 07:34 PM
  2. New acceleration vid
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 11-29-2010, 01:58 PM
  3. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
  4. Pop on acceleration
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2008, 07:07 AM
  5. No Acceleration issue
    By BooGTS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-10-2008, 08:16 AM
