Thread: fule gauge problem?
Results 1 to 3 of 3
  1. #1 fule gauge problem?
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    I have a 97 grand prix gt my fule gauge seem to be accurate until I get to about half a tank then the gaue is everywhere it fluctuates but usualy ends up reading full any one have any idea what's going on?
  2. #2 Re: fule gauge problem?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Sending unit in the fuel pump housing in the gas tank right in the trunk in front of the pass through in the back seat under the carpet under the oval-ish cover with about 10 10mm nuts would be my guess. Like the contact surface below half a tank is not making a good connection. Personally I would deal with it and just keep gas in the car... But I'm tired of throwing money at this thing, maybe your not lol
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #3 Re: fule gauge problem?
    Apr 2011
    Elk Rapids, Michigan
    Easy fix. I picked up the fuel level sensor on EBay for $24.95 shipped and received it in about 3 days. I couldn't find the part anywhere else. GM and the chain auto parts stores want to sell you the whole fuel pump assembly to the tune of $250 to over $500.
    I'm one to run my gas supply close to empty so not fixing it wasn't an option! It is easy to replace if you know how to get into the fuel pump assembly. It clips into the outside of the fuel pump canister and you do have to pop out the pins from the pump and replace them in the new connector that comes with the new part. You do have to swap the float assembly onto the new part. If you use search on here, I'm sure you'll find a write up on the fuel pump or even this exact repair.
    I found it from Global Automotive, NEW FUEL LEVEL SENSOR (FUEL PUMP SENDING UNIT) SK1195. Hope this helps.
  1. Another Fuel Gauge Problem
    By SilverGT in forum General Tech Discussion
    Last Post: 06-13-2012, 09:45 PM
  2. Fluctuating gas gauge problem!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 04-11-2010, 04:06 PM
  3. gauge problem
    By 1LoudGrandPrix in forum General Tech Discussion
    Last Post: 03-17-2010, 09:11 AM
  4. gas gauge problem
    By reinke in forum General Tech Discussion
    Last Post: 10-20-2008, 07:20 PM
  5. 97 gtp fuel gauge problem???
    By iwinagn in forum General Tech Discussion
    Last Post: 07-28-2008, 01:32 PM
