You won't be able to use the GTP PCM....your gear ratio is different in the transmission and that one will be set to the GTP ones and it won't drive right....You will need a total custom tune because of the additional compression and such. I wouldn't recommend trying to tackle the topswap tune yourself if you have no tuning experience. There is probably someone in your area who can help you out with that.
