I'm looking to buy a 2000 Grand Prix GT with roughly 120k on it that has a bad motor (sounds like a rod knock) for $700. The body is good and clean, interior is pretty clean, so I don't think it's a bad deal. It has a 3800 Series II in it which from what I have read should be an L36 and a 4T65E transmission.
I'm just looking to put another 3800 Series II in it, I'm not trying to change it to a GTP or anything, I just want to get a motor in it the cheapest and easiest way possible so I have a car to drive. I seen one thread where they had to change the PCM and some other things for the transmission to work properly, Will I have to do this as well? From what I read all the 97-02 L36's should be the same, so as long as I get an L36 from 97-02 should everything just swap motor wise and not have to do anything with a PCM?
Is there a certain year motor I should look for that has more power? I think I read the 01's had an upgrade in power? Would a Regal 3800 have more power than a Grand Prix 3800?
Are there any threads here that detail with pictures pulling the motor and dropping a motor?
Are there any places online that I could order a motor that I know will be reliable or has been inspected instead of just going to a junkyard and hoping I get a good one?
Anything I should expect with having to swap the motor?
