Found out the upper and lower o rings are not the same.
decided I would work on my valve cover gasket this weekend. Only did the left side so far. It was easy. Replaced the gasket and grommets on it.
I talked to a few people and everyone has a different oppinion on if I use rtv on the gasket or not.
I decided to go without since the original didn't have any.
Also discovered the valve cover gasket didn't seem to be leaking. The lower intake was leaking next to it making it look like part of the problem.
Guess I should have changed that first.
