Thread: Running hot where to start?????
Results 1 to 11 of 11
  1. #1 Running hot where to start?????
    SE Level Member Robby Avery's Avatar
    Deep South Georgia
    Ok guys need some help here. I've done a 180 therm a while back while I was doing wires and plugs. I noticed the my gf's car is running a litte to hot for comfort IMO but I'm not sure where to start. I probably didn't bleed the air properly when changing the the therm so I'm might start there. The cooling fans work but only when the computer tells them to when the temp is high. Also it climbs quickly at a stand still like a red light, drive through, etc. But once your up and moving and you get air flow across the rad it starts to cool down. Where do I need to start? Thanks in advance.
    Girlfriend's ride: 03 Summit White Grand Prix GT 180* T-stat, Autolites, Bosch wires, Custom CAI
    My Rides: 2006 LBZ CCSB LT3 Duramax Diesel Puller/DD
    2002 LB7 Duramax Diesel CCSB LT3 to many mods to list! Work Truck/DD
  2. #2 Re: Running hot where to start?????
    SE Level Member DC1263's Avatar
    Nov 2008
    Middlesex, NC
    Everything I can find tells me you should be running a 195' Thermostat as OEM on the 2003 ?
    So why the 180' ?
    Found this info very interesting, thought I'd share.
    The thermostat is much maligned, often misunderstood, and seldom credited for its mostly reliable service.
    Thermostats in proper working order, control only the minimum operating temperature at which engine coolant is allowed to heat. A properly operating thermostat has absolutely nothing to do with how hot the engine becomes. If you are experiencing an over heating engine, changing to a colder thermostat will not correct the condition, it only allows the coolant more time to over heat. A thermostat once fully open can do no more to control temperature. The overheating cause lays somewhere else.
    Some believe that removing the thermostat completely can remedy over heating concerns. This can be deceiving, with out some flow control coolant can pass through the radiator without slowing enough to cool, returning to the engine hotter with each circuit of the liquid.
    The temperature stamped or marked on the thermostat is the "start to open" rating. This is often referred to as when the thermostat just "cracks open" and allows some coolant to flow. This is in contrast to the popular belief that the temperature specification identifies when the thermostat is fully open. Most applications have a thermostat that is designed to "crack" at about 180 to 195 degrees F. If the thermostat opening is set too low or too high engine damage can be the result. High coolant temperatures can cause abnormal combustion, loss of power, damage to bearings and other moving parts, etc. Low engine operating temperatures lead to excessive fuel consumption, dilution of lubricating oil by the addition of unburned fuel, the formation of sludge from the condensation of water in the crankcase along with a host of other concerns.
    Thermostats are designed to be fully open 20' degrees F after cracking.
    So 215'+ on a 195' would be considered "Normal" as on my 2006, and the fans dont even come on till 230'
    Don't know how hot would be considered Too Hot, seen other post asking that, Maybe someone more knowlegable will chime in on that. So long as the pressure is holding the temp can go pretty high before there is a real problem.
    "The First Step In Successful Troubleshooting Is Eliminating The User As The Source Of The Problem"
    2006_Grand Prix_Liquid Silver Metallic_Black Leather_3.8_192,000
  3. #3 Re: Running hot where to start?????
    Florida
    I had a 180* in mine, and in 100degree + weather I would run 185 all day long. Comming to a stop light, I might get up to 200* at most.
    One instance after flushing the system, I didnt bleed it properly, and it wasnt totally full, so I would hit close to 215* when I came to stops, and like you said, would cool back down when you started driving..
    I'd crack the valve and see if you cant bleed it a little better, and add some more fluid, and see if that helps.
  4. #4 Re: Running hot where to start?????
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    so why does this problem pretty much only happen with grand prix's? every other car the tepm gauge doesnt move at a traffic light at all. is it the tepm sensor thats just screwed up?
  5. #5 Re: Running hot where to start?????
    St. Louis
    No, its the way that air loves to get trapped in the system and cause air pockets. These motors (not just in the GP's mind you) are a pain to bleed the air from. Once he gets that done the temp should hold just fine. I had to bleed my 00 GT 3 times before it finally quit doing what the OP mentions.
    Just nature of the beast.
  6. #6 Re: Running hot where to start?????
    Kansas
    Could also just be a fault CTS. Have you hooked it up for diagnostic and see what the actual running temperature is? And put the 195* back in, all your doing is wasting money on fuel. You can get a tuned PCM that turns the fans on earlier, and offers more than that.
  7. #7 Re: Running hot where to start?????
    And the answer to the problem is.. "it's normal"
    Low speed fan is programmed on at ~216F
    High speed fan is programmed on at ~228F
    Unless your pcm has been changed for a lower thermostat, the minute you get off the highway or stop in traffic. Expect temps to rise.
  8. #8 Re: Running hot where to start?????
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I had a similar problem like this when I did my LIM. Just try bleeding the coolant through the thermostat again. Fixed my problem.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
  9. #9 Re: Running hot where to start?????
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Bleed the radiator the old school way with the car jacked up and the rad cap off.
    If there is air pockets in your heater core the goofy bleeder on the thermostat won't get it.
    Usually people with the 180Tstats have the fans tuned to come on earlier, so if you're running one with the stock 195 fan settings that is probably why your temp spiking a little.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  10. #10 Re: Running hot where to start?????
    you always burp the system of big air pockets with the radiator cap off.....or at least i do...
  11. #11 Re: Running hot where to start?????
    Banned
    Apr 2011
    wv
    possibly deathcool. try flushing your rad, washing with water, and refilling with dexcool. we sell a flush kit at autozone for like $3 that has all the fitting to make it easy and simple.
  1. 00 Grand Prix Won't stay running/start
    By bankai in forum General Tech Discussion
    Last Post: 10-10-2011, 11:37 PM
  2. Engine Won't Start After Running for a bit
    By DesertFox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-14-2011, 08:36 PM
  3. Car running rough and won't start sometimes
    By metallica350 in forum General Tech Discussion
    Last Post: 12-02-2010, 09:43 AM
  4. 2000 gtp wont stay running after start??
    By handymontana in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2010, 06:42 AM
  5. Won't start after running out of gas
    By DesQ27 in forum General Tech Discussion
    Last Post: 02-13-2009, 07:59 PM
