Thread: 00 Grand Prix Won't stay running/start
Results 1 to 18 of 18
  1. #1 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    So here's the deal. I've been having this problem for a month. It started when my car shut off while driving. I was able to restart the car after I pulled the ECM(sense) fuse with the car in the on posistion and putting it back in. It got to a point where it would only drive 1.9 miles or a half mile at a time. After replacing the CPS it will start and shut off 30 secs later. You can't restart the car unless you disconnect the battery and wait 10 minutes to reconnect it.
    So far I've checked the Ignition Control Module for cracks and other faults, replaced my fuel pump (with a Walbro 255), cleaned my MAF, bought another ECM and replaced the Crank Position Sensor. I've also tried starting the car with the MAF unplugged. None of this has worked. After I replaced the CPS the Service Engine Soon light shut off.
    I'm tapped out of ideas.
  2. #2 Re: 00 Grand Prix Won't stay running/start
    Feb 2008
    Have you checked your fuel pressure and/or for spark when this happens? Do you have any other new or old weird things going on? Did you do or have any work done to it prior to these problems?
    You might want to take the ignition control module into Autozone and have it tested.
  3. #3 Re: 00 Grand Prix Won't stay running/start
    SE Level Member Phantom's Avatar
    Independence KY
    Have you checked the ground and positive cables? If there is rust on the connecting points it can make it hard to start or will not start. The cables may have corrosion on them not letting it start/stay running.
    I just thought when you replaced the ECM is that when it actually stopped running after 30sec? Why I ask is with VATS enabled on the ECM it might think that you are stealing the car and disable it after it starts. Try putting the old one back in.
  4. #4 Re: 00 Grand Prix Won't stay running/start
    Nov 2008
    norman oklahoma
    sounds like a security issue
  5. #5 Re: 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    All the grounds on my car are great. I replaced the ICM and put back in the orignal ECM. The car started. It sat there and idled for a good 30 minutes and then I drove it a good 15 minutes. Had absolutely no problems. Shut it off at the gas station and filled the tank. It wouldn't start back up. I did notice that the top part of the engine was incrediblely hot. My temp reading was in the norm and no trouble lights where on.
  6. #6 Re: 00 Grand Prix Won't stay running/start
    Feb 2008
    When it doesn't start.....when you turn the key does the engine turn over and it just won't start or is it like when you turn the key nothing happens?
  7. #7 Re: 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    It turns but doesn't start.
  8. #8 Re: 00 Grand Prix Won't stay running/start
    Then do you have fuel and spark?
    So does the fuel pump prime when you turn the key to "ON"?
  9. #9 Re: 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    Just checked the fuel pressure. It is not priming, again. There is spark. I'm going to order a new pigtail for the pump. It seems too intermitten on working or not.
  10. #10 Re: 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    Installed new pigtail. Still no fuel. Triple checked all the wires from the pump to the body. All is well there. Disconnected the battery and waited x amount of minutes. The car started. Drove it home. Now it won't start again. Any idea what sensors tell the ECM to shut the fuel off?
  11. #11 Re: 00 Grand Prix Won't stay running/start
    PK3 system does
  12. #12 Re: 00 Grand Prix Won't stay running/start
    Jul 2010
    Kissimmee Fl
    Did u check relays? when a faulty relay overheats it tends to fail, burnt prongs and excess voltage do that also... Good luck
  13. #13 Re: 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    Yes I checked the relays. And there is no security light to indicate a problem with the PK3. Does that matter?
  14. #14 Re: 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    It came down to taking it in to the dealership. I only agreed to do this since they said it's only $79 dollars to reprogram the ECM (which they look at and said didn't need to be done or to run diagnostics. That's a hell of a price drop from a couple years ago.
  15. #15 Re: 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    The diagnosis from the dealership came back as a bad fuel pump connector. Replace it. It helped, a little. All that did was make it so I could pull the ECM sense fuse to reset the whole thing, making it prime the fuel system. Still can't drive the car more than a mile at a time. So they're doing it again, for free.
  16. #16 Re: 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    After weeks the dealership asked for the other PCM to reflash it for my car. It didn't work. Now they've given up. They're just as mystified as me. Anyone have any ideas at all?
  17. #17 Re: 00 Grand Prix Won't stay running/start
    Jun 2010
    Stanwood, MI
    So one day the SES light comes on. The car quit shutting off. Checked the codes. Errors are the MAP and EGR. I'll replace them eventually. But now that it's running I'm not in a hurry.
  18. #18 Re: 00 Grand Prix Won't stay running/start
    Louisville, KY
    Just got back so bringing up the post kindof late, sorry. My 00 GP was running down the xpressway and would shut off, I'd put it in neutral and could turn back on but another 10 miles down the road it would do it again. After going thru all the normal stuff I had to check the camshaft/crankshaft sensor (Cant remember which one, behind the right front tire). Come to find out it wasn't reading so even though the car was running the pcm thought the car had quit so it would shut down the fuel pump and car would die while rolling. Cost me $65 and replaced it myself. I had access to the equip and shop but it still took 2 hours to fix. If you still have the car I'd look into that.
    My Cardomain
  1. Car wont stay running *HELP!!!
    By silverPGP in forum General Tech Discussion
    Last Post: 06-06-2010, 02:46 PM
  2. car wont stay running
    By 98gpgtp in forum General Tech Discussion
    Last Post: 04-17-2010, 07:41 AM
  3. Surging and won't stay running? help?
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 10:39 AM
  4. Car died in traffic, won't stay running.
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 10:28 PM
  5. Car will not stay running
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 07:30 AM
