Thread: suction noise
Results 1 to 11 of 11
  1. #1 suction noise
    GTP Level Member apierce1289's Avatar
    United States
    Ok when I start my car it makes a sucking noise but it goes away after the car warms up. It wasn't noticeable until I put the cone air filter on the TB. Oil was changed a few days ago along with fuel filter but the noise still exists. Is this normal since it may just be the sound of it sucking in air? Also my scan tool shows no errors and all dtc's show as ready except for evap (it always blinks). Also if I cold start the car and start driving the noise is more noticeable.
  2. #2 Re: suction noise
    Hagerstown,Md
    Its normal.
  3. #3 Re: suction noise
    Omaha, NE
    ^ This.
    All open cone intakes will do that.
  4. #4 Re: suction noise
    United States
    Just curious but why does the engine do this until its warmed up? I feel like learning rofl
  5. #5 Re: suction noise
    Hagerstown,Md
    Itrs the sound of the air passing thru the Idle air control valve
  6. #6 Re: suction noise
    Omaha, NE
    Because it idles higher until it warms up. More air getting sucked in = louder suction noise.
    Let it warm up then pull the throttle cable and it will sound the same.
  7. #7 Re: suction noise
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    my impala has fenderwall intake, the longer the tubing the louder it is. i think when the tubing is warmed up doesnt echo so much lol
    so i think..
  8. #8 Re: suction noise
    Quote Originally Posted by Grimsin View Post
    so i think..
    your theory is a little off.
  9. #9 Re: suction noise
    The stock airbox is designed to keep things quiet. Change the configureation and you get noise.
  10. #10 Re: suction noise
    St Thomas Ontario
    All i know is when the car is cold i dont hear the noise just at the filter, i hear it threw the entire tube. when the car is fully warm and i rev it to 1000rpm-1300rpms steady it does not make the same "suction" noise.
  11. #11 Re: suction noise
    Hagerstown,Md
    Quote Originally Posted by 01gpgt01 View Post
  1. New noise..again..help?
    By BwolfGT in forum General Tech Discussion
    Last Post: 11-03-2009, 09:47 PM
  2. noise
    By roadwarrior1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-15-2009, 03:21 PM
  3. Odd noise, can someone help!!!
    By indybrad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:06 PM
  4. Noise help
    By GMPUNK in forum General Tech Discussion
    Last Post: 02-08-2009, 05:07 AM
  5. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
