Thread: interchangable injectors
Results 1 to 7 of 7
  1. #1 interchangable injectors
    Apr 2009
    freehold,ny
    can i put l32 injectors on my l26 (no top swap)
  2. #2 Re: interchangable injectors
    Is your IDC at 80% or higher?
    If not so, its not worth having someone tune it.
    Seeing as you have a 2007 you'd also need an older PCM just to be able to tune, again adding to the cost.
  3. #3 Re: interchangable injectors
    Apr 2009
    freehold,ny
    i just need to know if there interchangable or not with out purchasing spacers or wiring harness, im not worried about the tune thanks
  4. #4 Re: interchangable injectors
    yes they are
  5. #5 Re: interchangable injectors
    Car is gonna run pig rich...if at all for that matter...
  6. #6 Re: interchangable injectors
    vacuum leak will help it run.
  7. #7 Re: interchangable injectors
    Jersey
    this doesn't make any sense unless your modded, almost maxing out your stock ones.
    16' wrx sti- stock
  1. interchangable parts list
    By Mayja in forum Brakes/Suspension/Chassis
    Last Post: 05-29-2010, 09:50 PM
  2. What do I do with my injectors?
    By FuglyGTP in forum General Tech Discussion
    Last Post: 04-01-2009, 02:12 PM
  3. 42.5# injectors?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2008, 02:17 PM
