Thread: SD headers
Results 1 to 20 of 27
  1. #1 Re: SD headers
    Delaware, OH
    Just wrapped it up. Sounds better but I'm pretty sure I cracked the number 4 spark plug cause it's got a solid miss in that cylinder. No heat in that primary after running (others were scaulding hot).
    Also, for you guy that've been running them for a while with no cat, Are you running the O2 sensor in the rear location? cause there's no way to install it without it hitting the tunnel wall. I extended it out for now to run off the rear O2 location.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  2. #2 Re: SD headers
    FWIW, you'll notice no RTV or unbolting of the dipstick tube for the trans in my post. Ed's was the first of three installs happening at my place this week. None will have either done to them.
    If you want to say putting that rear header in from above is the easiest way, I give you kudos.. to me that's like shooting yourself in the head to cure a weak headache. Tylenol (aka dropping the subframe) would have done the job.
    I've tried the various suggestions and honed it down to what works best for me. That's me. I'm a right handed average sized guy working in his home garage. No lift, not too many fancy tools.
    Blue..that's how I roll.
  1. Which headers to go with?
    By DEC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2013, 11:19 AM
  2. headers
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2009, 10:19 PM
  3. headers
    Last Post: 07-10-2009, 01:36 AM
  4. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
