Thread: Differences in blocks?
Results 1 to 8 of 8
  1. #1 Differences in blocks?
    Never Never Land
    Long story short the replacement motor for my Camaro is toast.....so I think i'm gonna pick up another cheap one and rebuild it and just get the body finished for right now.
    My question is is there any differences in the blocks between the L26/L36 AND L67/L32. Also FWD and RWD. Any differences in the blocks?
  2. #2 Re: Differences in blocks?
    No...compression ratio yes...everything else short block wise is the same.
  3. #3 Re: Differences in blocks?
    Never Never Land
    (factory) compression ratio doesn't concern me a whole lot.
  4. #4 Re: Differences in blocks?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    There are a number of block differences if your asking about internals. Actual block casting, no. L36 has longer rods,shorter pistons, non coated pistons,and tighter ring clearances as opposed to the l67. The l26 has stronger rods then the l36
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: Differences in blocks?
    Never Never Land
    block itself...only thing that really matters to me is the crank.
  6. #6 Re: Differences in blocks?
    Cranks are all the same.
    Also...strength of ANYTHING in these motors are debatable...since countless motors have gone over 600 FWHP on a bone stock bottom end...it is all in the tune.
  7. #7 Re: Differences in blocks?
    Banned
    Mansfield, Ohio
    600hp on a stock block is impressive!
  8. #8 Re: Differences in blocks?
    Never Never Land
    im building the bottom end...im not takin any chances...this will be the third motor..i dont want a fourth lol
  1. the differences
    By noom14921992 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2011, 04:00 PM
  2. Spring blocks
    By 01gpgt01 in forum General Tech Discussion
    Last Post: 09-06-2010, 01:45 AM
  3. Can L36 short blocks be used in an L67??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2010, 07:54 PM
