Thread: Can L36 short blocks be used in an L67??
Results 1 to 5 of 5
  1. #1 Can L36 short blocks be used in an L67??
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Just wondering since i threw rods in my l67, can just replace it with the short block from my old l36? If so, what size pulley should i use? I know the stock on it now is like 3.8. And where could i buy the larger pulley from?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Can L36 short blocks be used in an L67??
    L36 bottom end + L67 top end + headers = win
  3. #3 Re: Can L36 short blocks be used in an L67??
    Bowie, MD
    Thanks so much matt. I appreciate it. Im going to tell the shop to swap the short block from my l36 into my l67 tommorow and i will then order my headers tommoroow also. This will at least allow me to get my car back on the road again and give me time to get a l67 short block for later use just in case. Appreciate it matt. Can i still drop pulleys at the same modded rate as normal?
  4. #4 Re: Can L36 short blocks be used in an L67??
    if you want to drive your car after the swap i suggest leaving the blower belt off and avoiding WOT till you get it street/dyno tuned.
    You have to drop pulley's slower because of the higher compression.
  5. #5 Re: Can L36 short blocks be used in an L67??
    Bowie, MD
    Okay. Thanks again.
  1. short ram intake
    By digilue in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-29-2008, 04:08 AM
  2. Electrical Short Maybe????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 12-02-2008, 07:56 AM
