Thread: temp gauge issues
Results 1 to 4 of 4
  1. #1 temp gauge issues
    Lansing, MI
    I changed the coolant temp sensor on my 02 Gt. Now my temp gauge goes to 240 on the highway and about 220 cruising in the city. With the original CTS the temp stayed under 210 always. I tried burping the system. I tried opening the bleeder screw, and changed the thermostat. Still no change. The cooling fans are not coming on so that tells me that the motor is really not that hot.? I've tried a coolant temp sensor from autozone, a BWD one from Advanced Auto, and an Elchin one from Napa. Should I try a delphi sensor or one from the dealer. I've searched this site up and down, and I don't know what else to try or where else to look for a problem. Any input is greatly appreciated. Thanks.
    2002 GT 4dr
  2. #2 Re: temp gauge issues
    St. Louis
    Do the cooiling fans come on if you run the A/C? Almost sounds like a fan issue and not the CTS.
  3. #3 Re: temp gauge issues
    Lansing, MI
    I went to the dealer and got another cts. Installed it last night. Problem solved. Temps are normal again. Thanks.
    2002 GT 4dr
  4. #4 Re: temp gauge issues
    SE Level Member bigwillie's Avatar
    Apr 2009
    Clinton Twp. Mich.
    I replaced mine with one from Oriellys and the same thing happened, temp gauge is outta whack. You're saying one from the dealer fixed your problem?
  1. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
  2. Temp Issues
    By rildin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 10:09 AM
  3. Temp Gauge running hot
    By Thexfactord22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2010, 02:43 AM
  4. Temp gauge
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 01:39 AM
