Thread: thermostat replace with 180
Results 1 to 20 of 23
  1. #1 thermostat replace with 180
    SE Level Member ham4864's Avatar
    Nov 2010
    usa
    what year make model to use when asking for one at the parts store,the guy says they don't make one for the 04 grand prix.
    WhatAPrix
  2. #2 Re: thermostat replace with 180
    Akron Ohio
    Id keep your stock one in.
  3. #3 Re: thermostat replace with 180
    Quote Originally Posted by ham4864 View Post
    Quote Originally Posted by JoshsGTP View Post
    *sigh*
    Search guy...try the first 2 links if you don't know...
    Let me google that for you
  4. #4 Re: thermostat replace with 180
    id keep the STOCK temperature range as well.
  5. #5 Re: thermostat replace with 180
    id keep the stop temperature range as well.
    Yeah..I like the stop temp too
  6. #6 Re: thermostat replace with 180
    Awesome.
  7. #7 Re: thermostat replace with 180
  8. #8 Re: thermostat replace with 180
    So, just like every other night?
  9. #9 Re: thermostat replace with 180
    New Jersey
    Whats the stop temp? Around 300F?
  10. #10 Re: thermostat replace with 180
    stock? 195*?
    LOLz
  11. #11 Re: thermostat replace with 180
    Charles City, IA
    stop....hammer time.
    SMGPFC Two Nipple General
  12. #12 Re: thermostat replace with 180
    New Jersey
    stock? 195*?
    LOLz
    No, I assume stop temp means when it seizes
  13. #13 Re: thermostat replace with 180
    SE Level Member trickytransam's Avatar
    Michigan
    I always drill a small 1mm or less hole in the thermostat plate. Install the hole at the 12:00 position (Up) so it naturally bleeds out air as you refill the cooling system.
    The procedure for deaeration is to idle and rev idle and rev, but with this mod, you only have to fill, idle, and drive. Works for me every time.
  14. #14 Re: thermostat replace with 180
    GT Level Member sasquatch094's Avatar
    cleveland
    Hey tricky, got a write up to your 1mm hole thing?? i gotta change my tstat here shortly. take out the dexcool completely and replace with green, or flush and replace??
  15. #15 Re: thermostat replace with 180
    you take the t-stat and drill a hole in it.
    if you need a write up for that how would you ever hang a picture in your house?
    That won't bleed the system either. that just lets coolant and air flow when the t-stat is closed.
  16. #16 Re: thermostat replace with 180
    cleveland
    well if 2 people are telling me different stuff then which one is right? well i guess i wont do either of them..
  17. #17 Re: thermostat replace with 180
    GT Level Member neel2008's Avatar
    Huntington, IN
    its the internet, thats how it works round here.....
    97gtp
  18. #18 Re: thermostat replace with 180
    New Jersey
    thats not just the internet, thats life.
    You ask 10 people a question and see what answer you get most. If you get a lot of conflicting answers you use your best judgment based on the answers you got from people.
    Me? I use a 195F stat as per stock and follow GM's bleeding procedure.
  19. #19 Re: thermostat replace with 180
    Dec 2008
    Lawndale, CA
    If you are stock or have small mods with a stock tune then stick with the 195.
  20. #20 Re: thermostat replace with 180
    Grand Rapids, MI
    when i replaced my 3800 it came out of a 96 regal and i assume it had a 180 tstat in it.
    if what you are saying about stock, should i change back to 195 or leave it be?
  1. Best thermostat
    By ATLgrandprix78 in forum Introductions/Noob Questions
    Last Post: 08-12-2010, 08:55 AM
  2. Thermostat!????
    By fratzke7 in forum General Tech Discussion
    Last Post: 03-16-2009, 11:35 AM
  3. thermostat
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 06:38 PM
  4. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
  5. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
