I always drill a small 1mm or less hole in the thermostat plate. Install the hole at the 12:00 position (Up) so it naturally bleeds out air as you refill the cooling system.
The procedure for deaeration is to idle and rev idle and rev, but with this mod, you only have to fill, idle, and drive. Works for me every time.
