Thread: Engine Shutter
Results 1 to 5 of 5
  1. #1 Engine Shutter
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    I have a 2004 GT. So while I'm driving between 68-83 the car will randomly feel like it bogs down and it shutters for a couple seconds, then will drive normal until it does it again. I feel like it might be the crank position sensor, but I'm still not sure.
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  2. #2 Re: Engine Shutter
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    How many miles? Codes? Can you scan it?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  3. #3 Re: Engine Shutter
    Spring Lake, Mi
    150,000, it has the trac, abs, ses on, and i got it read, but all they say is oxygen sensor
  4. #4 Re: Engine Shutter
    Jacksonville, Fl
    I had some very similar symptoms and it ended up being a clogged cat
  5. #5 Re: Engine Shutter
    Spring Lake, Mi
    I'm feeling like a cat delete will be my sunday project
  1. Engine Shutter
    By Jakescoots in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2010, 05:12 PM
  2. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  3. Shutter while downshifting at highway speeds (50 to 65 MPH)
    By GPdude97 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2009, 02:52 PM
  4. Help with a GTP with a shutter
    By Black18Ice in forum General Tech Discussion
    Last Post: 08-21-2009, 07:15 PM
