Thread: 2000 GP GT no spark!
Results 1 to 10 of 10
  1. #1 2000 GP GT no spark!
    Nov 2010
    mabank
    Hi all, I have a 2000 GP GT, It started out by dieng when taking off from a stop, It would'nt start every once and a while and if i let it sit for 5 / 10 min it would run fine, the car would run perfect or not at all. I changed the fuel filter and was pluged with sludge, i changed the crank sensor, one of the coil packs that was visably cracked, the oil was full of gas from cranking it over so i changed the oil, the water pump was leaking so i changed it out, thinking that was what messed up the crank sensor. I have put it all back together now and it's not even starting at all.. Its getting gas in the rail, and i checked one of the wires for spark and it's not getting any.. I dont know what else to do!
    thanks for your time and any help is welcome, ToXiC
  2. #2 Re: 2000 GP GT no spark!
    St. Louis
    Have you checked all the underhood fuses?
    Does the tach move while trying to start it?
    Jay
  3. #3 Re: 2000 GP GT no spark!
    Jul 2008
    sumter,south carolina
    ignition control module possibly? was the crank sensor causing u to stall? or were u just getting codes for it?
    02 GTP with mods 05 GP for DD
  4. #4 Re: 2000 GP GT no spark!
    Nov 2010
    mabank
    Hey Jay, I have checked the fusses under the hood and all are good, and yes the tach does move up a little when i crank it over. thanks Toxic
  5. #5 Re: 2000 GP GT no spark!
    Nov 2010
    mabank
    Hey Pinsc, ignition control module could be my problem, im going to check that out... and the car won't even start now that i changed the crank sensor, so im gussing its not the problem. I havent ran a code check on the car since the last time I had problems with it, It threw a mass air sensor code so i unpluged it and it ran fine untill a few months later and the stalling issues all came up. havent ran a code since. Thanks for the help guys..
  6. #6 Re: 2000 GP GT no spark!
    You ran the car without the MAF for a while?
    Did you ever go WOT? Because thats not good for the car.
  7. #7 Re: 2000 GP GT no spark!
    Nov 2010
    mabank
    Yeah i did, and im not sure what WOT means?
  8. #8 Re: 2000 GP GT no spark!
    Jul 2008
    wide open throttle.
  9. #9 Re: 2000 GP GT no spark!
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    The MAF is a VERY important sensor. Replace it.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  10. #10 Re: 2000 GP GT no spark!
    Nov 2010
    mabank
    Thanks guy's, will do!
  1. 3.1 and no spark
    By TAYLORPCC in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2010, 01:45 AM
  2. No spark HELP!!!
    By Machzzzz1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2010, 12:30 PM
  3. 72 gp sj no spark
    By rayzo63 in forum General Tech Discussion
    Last Post: 02-16-2009, 10:40 PM
  4. no spark
    By faboskay57 in forum General Tech Discussion
    Last Post: 07-10-2008, 07:41 AM
