Thread: no spark
Results 1 to 13 of 13
  1. #1 no spark
    Jul 2008
    amsterdam ny
    my 97 grand prix gtp has no spark i drove to the store shut it off went to leave and it wouldnt start found that it had no spark can anybody tell me what i should do first?
  2. #2 Re: no spark
    Barksdale AFB, LA
    How have you figured you have no spark?
    2009 Subaru Impreza WRX STI
  3. #3 Re: no spark
    Jul 2008
    amsterdam ny
    i pulled a wire off and put a spark plug in the wire and had a buddy crank it over no spark
  4. #4 Re: no spark
    Barksdale AFB, LA
    I'm not so sure that's a valid test, but assuming there's no spark the ICM would be suspect.
  5. #5 Re: no spark
    I live here. UR LOSN's Avatar
    Rockford, IL
    does the rest of the car have power? are you able to take the key out of the ignition?
    EDIT: in order for the spark plug to have spark..you have to have the threads touching the block/and or something for a ground.....
  6. #6 Re: no spark
    Jul 2008
    amsterdam ny
    yup the rest of the car has power the key is fine i was told maybe a crank sensor?
  7. #7 Re: no spark
    Rockford, IL
    There is a write up on how to replace the crank sensor in the "HOW TO" section
    if you really feel it is indeed that
  8. #8 Re: no spark
    Saraland Alabama
    crank sensor, pcm, ignition module, coils all can do that
  9. #9 Re: no spark
    Apr 2008
    Chillin at the Beach , VA
    If it was the crank sensor, wouldn't he go through some random stalling first like most of us has. Not sure if this is right, just trying to learn something new. I'm going through the random stalling now and was told most likely was the CPS. That's why I ask.
  10. #10 Re: no spark
    Rockford, IL
    I would have him retest the spark issue with the threaded end of the plug grounded...to see if he has spark.........
    If he verified it this way, then we can move on.....
  11. #11 Re: no spark
    Jul 2008
    amsterdam ny
    yeah i grounded out the spark plug it def dose not have spark my buddy tested the wires to the icm and it has power going to it im gonna try replacing the icm
  12. #12 Re: no spark
    Jul 2008
    amsterdam ny
    hey thanks guys i got it fixed it was the icm i got a used one with the coil packs for $20
  13. #13 Re: no spark
    Apr 2008
    Glad to see you got it fixed.
  1. Bosch Spark Plugs?
    By DanGTP in forum General Tech Discussion
    Last Post: 04-23-2008, 02:24 PM
  2. A look at different types of spark plugs
    By SyntheticShield in forum General Tech Discussion
    Last Post: 04-10-2008, 11:24 AM
  3. spark plug gapping?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 10:15 AM
  4. spark plug gaps
    By MTXGTP in forum Off Topic Discussion
    Last Post: 03-01-2008, 07:58 AM
  5. Spark plug Reviews
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 10:06 AM
