Thread: Lifter/ticking noise???
Results 1 to 13 of 13
  1. #1 Lifter/ticking noise???
    Donating Users kind153's Avatar
    Pittsburg, KS
    1998 GP, 140k
    This noise started yesterday (11/12/2010) when weather got cold.
    It started in the morning, I drove a mile, disappeared. (about 9:00)
    Around 1:00pm, it wasn’t there when I started, drove to work, no noise. (1:40pm)
    It rained VERY hard while I was working inside. When I got off work, 4:00pm, it was worse. That’s when this video was recorded.
    Took it to a shop on my way home(30mi, 4:45pm), it was still there. I thought it was somehow related to raining because it was raining on my way home. They added BG MOA, hoping to clean lifters, I was also told that this won’t harm anything.. (hmm?)
    So I did some googling last night, and I found a suggestion to rev to 3000rpm for 15 seconds, idle for 15 seconds, repeat.
    Tried that this morning(11/13/2010), and it went away after doing it about 5 minutes. So it seems to go away when enough oil pressures builds up? I guess?
    I tried driving anyway with the noise, it doesn’t seem to affect its drivability, but if I don’t get rid of the noise with revving up, it will follow me to my destination. ::
    Here’s some records that’re done recently.
    11/9/2010 had a coolant leak. Replaced: hose fitting, t-stat, upper radiator hose, water outlet(L elbow I think), upper intake plenum, EVAP solenoid.
    10/25/2010 regular oil change. Changed brand from Quakerstate to Valvoline.
    I read somewhere Valvoline can cause this..but I can’t find it again.
    Here’s the video:
    YouTube - lifter noise when cold
    Any suggestion is appreciated.
    PS - disregard my low coolant light.. bad sensor.
  2. #2 Re: Lifter noise???
    it could be a lifter or maybe you broke a spring. im not really sure
  3. #3 Re: Lifter noise???
    Pittsburg, KS
    update: the noise seems to go away in shorter period of time today. getting better ??
  4. #4 Re: Lifter noise???
    Pittsburg, KS
    update: it's back.. sounds still same amplitude. any help???
  5. #5 Re: Lifter/ticking noise???
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    I would just have someone take a look at it...They probably need an adjustment, one might be a little loose or have some gunk in it that needs to be cleaned out. If a lifter needs replacement it can be expensive sometimes. I know on a lot of cars you need to remove the timing belt and cam to replace one. Not quite sure about if it would be a lot of labor on one of our cars since I've never had to do mine...wouldn't hurt to take a look or if you can't have someone you trust do it
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  6. #6 Re: Lifter/ticking noise???
    Pittsburg, KS
    thinking of running seafoam....good idea?
  7. #7 Re: Lifter/ticking noise???
    Jul 2010
    Holyoke, MA
    I would go ahead and give it a shot....Just don't run it in there for too long, it thins the oil a lot....there are also a lot of people that advise against it for the fear of eating away at the seals, but just don't leave it in there for a month and you wont have a problem.
  8. #8 Re: Lifter/ticking noise???
    Pittsburg, KS
    Quote Originally Posted by Dtrick22 View Post
    yeah that's what I hear; before 100 miles of oil change. gonna update soon!
  9. #9 Re: Lifter/ticking noise???
    Jul 2010
    Holyoke, MA
    It probably wont fix the problem, but might dampen it a little bit. It's pretty loud so I would bet it needs an adjustment or has a broken spring, but at the cost of a can of seafoam, its worth a try first.
  10. #10 Re: Lifter/ticking noise???
    Jul 2010
    Holyoke, MA
    Any luck?
  11. #11 Re: Lifter/ticking noise???
    Pittsburg, KS
    sorry for the late.. I only did seafoaming through vacuum line, and I'm not sure either it or driving 'agressively' did, but it hasn't been back since last week. Considering BG MOA was in crankcase, I can't tell if it did it or not..
    Anyway, it is gone!
  12. #12 Re: Lifter/ticking noise???
    Thats OHC.
    Welcome to the fun of owning a pushrod car.
    Take off the fuel rail, take off the intake mani, take off the lower intake mani, take off the valve cover and associated rocker and the lifter retainer and boom its out.
    Still time consuming, but you cant nuke your engine because you're not messing with the cam timing.
    Glad the op got this solved somehow.
    Through the vacuum line would only touch the valves, not the lifters though. Oh well...
  13. #13 Re: Lifter/ticking noise???
    Jul 2010
    Holyoke, MA
    Lol, I was thinking the same thing
  1. loud lifter noise any ideas?
    By breeze12 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 02:12 PM
  2. Bad Lifter?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:03 PM
  3. Ticking noise, thinking lifter
    By bradford82 in forum General Tech Discussion
    Last Post: 01-25-2009, 10:44 AM
  4. Colapsed Lifter?
    By jbizach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2009, 08:48 PM
  5. Lifter Tick
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 06:43 PM
