Thread: need ur help!!! regarding a tube coming out of the engine.
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: need ur help!!! regarding a tube coming out of the engine.
    Destroys cars izup69's Avatar
    Iowa
    Like they said the first 3 picks are your vac like for your brakes. The plastic t that fits in that big round black thing (break booster) its a simple t fitting with a rubber gasket. Should be able to pick it up at a local parts store they may not have one exactly for the grand prix but there are alot of cars with ones just like it. As long as there is no leak there it moving around is no problem. To check for a leak just put some smoke by it see if it is sucking it in. The other 2 picks are of your injectors. And agen as they said they can move around all they want as long as they are not leaking gas. Another way to test that vac line to see if it is leaking is to pull it out of the break booster you should hear a woosh of air rushing into it if you dont then its leaking. Ill post some picks here in a min of what I'm talking about by rubber gasket
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  2. #22 Re: need ur help!!! regarding a tube coming out of the engine.
    Charles City, IA
    That is completely normal for the fuel line to move in and out a bit on that style of connector. Dont worry about it.
    SMGPFC Two Nipple General
  1. Replies: 13
    Last Post: 04-12-2010, 08:45 PM
  2. Weird noise coming from my engine bay *with video's*
    By nawarkk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2010, 01:32 AM
  3. Engine overheats, heater blows cool air, leak by egr tube
    By twillroth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2009, 03:13 PM
  4. weird noise coming from engine
    By q1w2e3r4t5 in forum General Tech Discussion
    Last Post: 04-02-2009, 09:59 PM
  5. Grinding noise coming from my engine
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 04:24 PM
