You dont need the clips. All mine are broken off. It just helps hold the oring. Most break them when they roll the O-ring off the injector. No worries
Here is a pic of what I mean. If you look at the end of the right hand injector you will see the missing tip...
01gpgt01- So it should still be good to go like this? I mean, the new o-ring is on ok (as seen in pic), but wasn't sure if the plastic tip served any purpose as to direct the fuel spray or something along those lines. As long as it doesn't leak fuel that's all I care about.
Jay
