ALMOST...
done.
get it running already.
And did a cam make its way into this?
at least headers?
I dont read the sigs of people who I know haha.
And sweet, should be much better than before.
It's done for the most part, however, some tuning daemons still lurk under the hood, including a craptastic place to locate the O2 sensor, which will need to be fixed before any REAL tuning can be done unfortunately.
Getting the O2 put in tomorrow and the leak fixed. Oh and I probably have the longest O2 extension ever Thanks Jay
If anyone can help us with a problem though.. Im getting the P0121 Code which is the tps sensor.. We figured maybe it was a bad sensor so i replaced it with the one from my gt.. ran fine for a while but now its throwing the code.. I cleaned it up where the plug is and cleared the code and I have no problem now and the code is gone.. If it comes back though what would it be since we know its not a bad sensor?
No problem dude, glad I had a lot of wire. I know it's ridiculous, but really I didn't know what else to do for a temporary fix. I know a lot of guys said they had to dent in the floor for their O2 to fit with the Speed Daddy headers, but yours must be a little different. No way a nearly 4" long sensor was going to fit with only 2" of clearance from the bung to the floor. The exhaust shop tomorrow should make easy work of relocating it for you. Have them put it where I showed you and you can just plug that replacement O2 sensor in I gave you without an extension.
No way in God's creation that was happening.....by the time we put the dogbones back on, it pulled the bung up close to the top of the tunnel. It's going in the crossover where it's gonna be easy to get to.
Sometimes I think these guys are full of **** when they design headers....It's not that hard. I'm starting to hate header installs.
Hey Nick i fixed your signature
2003 Blue-Black Metallic GTP Sedan - Custom Flat Lobed Cam, Melted Spark Plug in the Head Mod, Piston Ring Wrapped Crankshaft, Stripper Glitter Oil Pan, Crescent Shaped Pushrods, Oil Pressure and Piston Delete, Valve Head Removal, Slinky Valvesprings, and much, much more!! Stolen MAP Sensor*
