Thread: Swapping '03 radio for '04-'08
Results 1 to 7 of 7
  1. #1 Swapping '03 radio for '04-'08
    Ontario
    Hi everyone,
    The display on my radio is going. Goes dim/bright often but also goes out sometimes. Other times it displays garbage on the screen instead of numbers. My car is a 2003 Grand Prix GT with the steering wheel controls and HUD. Is it possible to swap this radio with an '04-'08 model? Would it fit properly and plug in without changing the wiring? Would the steering wheel controls still work?
    Thanks,
    ron
  2. #2 Re: Swapping '03 radio for '04-'08
    GTP Level Member SuperSport's Avatar
    Michigan
    Im guessing those won't work. The radios in our cars can be found in Grand Prix, Grand Ams, Firebirds, sunfires, Montana's, etc. Theyre a dime a dozen in the Junkyards. Just go pick up a new one from there, change the bulb in the display while you have it out and install it.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Swapping '03 radio for '04-'08
    Willoughby, Ohio
    or if you have money buy and aftermarket one and buy the steering wheel control interface
  4. #4 Re: Swapping '03 radio for '04-'08
    GTP Level Member
    springfield IL
    dont do its just a dumb idea... if you like your music buy an aftermarket deck!!
  5. #5 Re: Swapping '03 radio for '04-'08
    Michigan
    Quote Originally Posted by CTKGP09 View Post
    Which looks like crap.
  6. #6 Re: Swapping '03 radio for '04-'08
    Ontario
    Okay everyone thanks for the heads up. I'll just get a replacement. Is there anything special I need to do with regards to the Theftlock? I'd hate to get that thing activated by accident.
    1. Disconnect battery
    2. Replace radio
    3. Reconnect battery
    Is this correct or a recipe for disaster on grand prix's?
    Thanks again,
    Ron
  7. #7 Re: Swapping '03 radio for '04-'08
    Willoughby, Ohio
    check your owners manual to turn off theft lock so you dont have to worry about it. ive never had it on in my GP. if its on then you have to enter a code i believe. but once you set it to on or off, it stays like that
  1. Swapping engines
    By dbz09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2009, 12:51 PM
  2. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
  3. 99 GTP vs. 97 GT Swapping Parts
    By Bandit1228 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 09:40 AM
  4. Swapping Engine
    By Redgtp1999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 08:06 PM
  5. Detop swapping the GS???
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 05-26-2008, 12:23 AM
