Thread: 97 GT intermittent start please help
Results 1 to 7 of 7
  1. #1 97 GT intermittent start please help
    Greetings all,
    This may be a bit lengthy so please bear with me. My wife's 97 GT (60K miles) has had an intermittent start problem for awhile now. 9 times out of ten, the car starts right up and runs fine but occasionally when you turn the key, the starter engages but won't spin the engine for a half a second and then starts right up. Other times, when you hit the start position on the key, nothing happens. You can usually turn the key off and back on a couple of times and the car starts right up or just hold it and around a half a second later the starter kicks in and works. When it's running, there are no warning lights, it doesn't overheat, runs fine and is very driveable.
    Until this morning, this was only happening with a hot engine but now it will do it on a cold start as well.
    It really acts like a dead battery or something dragging the battery down but even if the car sits for over a week, it will usually start right up.
    Here is what I've done so far:
    Ignition switch harness was replaced at about 40K miles due to a AC fan issue.
    I've replaced the battery, the starter, redid the battery connections and replaced the main ignition relay as well. Alternator is putting 14.4 volts across the battery. I don't have a code scanner and am afraid to take it to get it scanned in case it strands me as I can't afford a tow. It doesn't act like the park switch as most of the time the starter will engage, just not spin the engine for half a second or so. Other times, the starter will not engage for a half second or so then fire right up.
    I'm at wits end on this one. We can't drive the car as we don't trust it and it is really starting to cause problems as we need it. The car has been driven less than 100 miles in the last two years due to this. I'm almost thinking the battery is just not being charged enough but as I said, 9 times out of 10, it fires right up, even after sitting for a week or more.
    What really scares me is the thought of something in the engine not letting it spin but as I said, the way it runs and drives gives no hint of a problem. The last time I took it out, it was twenty miles down the interstate and back home in traffic on back roads then I let it sit in the driveway in the sun ( 90 degress in Florida) running in drive with the AC on for an hour with no issues. I turned it off, waited a minute and then no start the first try and fired right up the second.
    We've had three GTPs and this GT in the family but none of the others has done anything resembling this. My current 02 GTP has 160K miles and still runs like the day I bought it off of the showroom floor.
    Any thoughts would be greatly appreciated. Thanks in advance.
  2. #2 Re: 97 GT intermittent start please help
    I see there has been some views but no responses. Just want to say thanks anyway.
  3. #3 Re: 97 GT intermittent start please help
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    it sounds like the starter to me take it off and have it tested a few times on the machine at auto parts... let us know...
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  4. #4 Re: 97 GT intermittent start please help
    Bastard Reptile's Avatar
    Kansas City, MO
    Check your grounds from the battery, it sounds like a ground problem to me. And then double check to see if your cables are snug on the battery.
  5. #5 Re: 97 GT intermittent start please help
    Thanks for the replies.
    I have replaced the battery and starter as well as replaced the battery terminals on the cables. As near as I can tell, the main ground connection at the block is good. It's clean and tight but I need to by a wrench that will get to it and don't know the size. I swapped the relay in the fuse box with another one just like it. The relay is called the ignition relay and I'm wondering if that is the "starter" relay or if there is a starter relay somewhere else.
    Right now. I'm working on funds for the ignition switch harness even though it was changed at 40K miles (60K on car now). I've been taking the car out on a pretty regular basis and it drives great. It's never failed to start on the second or third try if needed but the wife doesn't trust it. Neither do I.
    Thanks again for the ideas. Keep them coming. I'll definitly post anything I come up with. Airhead
  6. #6 Re: 97 GT intermittent start please help
    SE Level Member Beauty026201's Avatar
    Jun 2010
    Cape Cod, MA
    Have you checked the coil packs? One bad pack will cause intermittent start problems without throwing a code. Also, it could be the neutral safety switch on the tranny. Hope this helps.
  7. #7 Re: 97 GT intermittent start please help
    Thanks Beauty026201. I really appreciate the responses from you as well as Reptile and mikedinthecity.
    I've thought about the neutral switch and will try and check that on my next day off(Wed.) As far as the coils go, when this happens, the engine won't even spin over. Can a coil cause that? I did notice the last time I drove it, if you get into it pretty hard there is a VERY SLIGHT miss under load. Normal driving, you don't feel it and the car runs fine. The problem is when you try and start it. It's like you unhook the starter. You get all the lights, the fuel pump is running but when you turn the key to start, nothing happens. If you release it, pull the key out and try again, it starts right up.
    I did think of something else this morning. There is an after market alarm system in the car that the dealer installed. The installation work is really bad and the dealer is no longer in business. It will kill the ignition. I'm going to try and bypass that part of it and see what happens.
    Thanks again for all the input.
  1. 3.8L SC Random stalls, faulty intermittent start!
    By agentbluescreen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 01:22 PM
  2. Intermittent No heat
    By Toasty in forum General Tech Discussion
    Last Post: 09-25-2009, 07:44 PM
  3. QUESTION? intermittent window
    By SammyC1 in forum Shops and Community Heroes
    Last Post: 09-24-2009, 05:22 PM
  4. 97 GT intermittent start
    By airhead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2009, 06:43 AM
  5. Intermittent idiling around 2k & other Stuff
    By FlatlinerD in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2008, 10:33 PM
