Thread: Really need some help, stuck oil filter
Results 1 to 17 of 17
  1. #1 Really need some help, stuck oil filter
    Pennsylvania
    I've been trying for over 3 hours to get this filter off, I tried using a cloth, my barehand.. one of those ones that constrict and get tighter as you apply force, and then I read to drive a screw driver through it and use that to get some leverage... it just tore the metal around the hole.
    My hand is killing me already, and I just want the damned filter off. Can anyone help here?
    I even used this vice grip thing from Fram and that just broke the casing worse.
  2. #2 Re: Really need some help, stuck oil filter
    Dumb question but are you turning the right way.
    I would have said screw driver too but you already did that. Maybe get the crew driver ot go all the way threw the filter and turn. Do you have one of those things that go on the bottom of the filter and you turn it with a socket wrench?
  3. #3 Re: Really need some help, stuck oil filter
    Pennsylvania
    Ok, another dumb question just to be positive.
    Let's say the front of the filter (The portion of it facing the headlights, or front of the car).
    Which way, Left or Right, would I want that front facing part to turn?
  4. #4 Re: Really need some help, stuck oil filter
    you want to turn the filter towards the rear of the car. to get it off
  5. #5 Re: Really need some help, stuck oil filter
    Delaware, OH
    turn it like it's going from the Driver side headlight, to the passenger side headlight, round toward the back of the car.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  6. #6 Re: Really need some help, stuck oil filter
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    this is good
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  7. #7 Re: Really need some help, stuck oil filter
    Pennsylvania
    Well, 4 other guys along with myself worked on it for almost 5 hours and it barely moved. We tried damn near everything imaginable. It's just mutilated to hell now. One of my friends who was there tonight, his dad is a genius at automotive problem solving, and generally we have a joke that "If it cant be done, Bob's dad hasnt tried it yet", lol. So Im hoping as it's my daily driver.
    So, there's nowhere left to poke a hole with a screw driver, none of the wrenches fit, and 5 fully grown men were unable to move it by hand.
    Given the diagram, we were indeed moving it in the right direction.
    Any suggestions are greatly appreciated.
    Ugh, how the simplest things can turn into such an ordeal. Im tired and defeated, so bed time, lol.
  8. #8 Re: Really need some help, stuck oil filter
    Go get another oil filter adapter...unbolt the the 4 bolts behind the filter...get a new gasket and '04+ spring kit too...and toss it along with the filter if thats the case. It might be a sh1tty deal but it'll get you back on the road.
  9. #9 Re: Really need some help, stuck oil filter
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Try turning it with a pair of channel lock pliers. Keep the jaws near the top of the filter (near O-ring).
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  10. #10 Re: Really need some help, stuck oil filter
    New Jersey
    could perhaps try using a cold chisel and a hammer and get it to turn with it. Like the trick you use to get rounded bolts out. the shock helps knock it loose and the chisel will dig in to get it to turn.
    Whatever you do don't let the chisel hit the mating surface on the oil filter adapter
  11. #11 Re: Really need some help, stuck oil filter
    Apr 2009
    stockton ca
    blues right might be the only way
  12. #12 Re: Really need some help, stuck oil filter
    Pennsylvania
    Got it
    It took much blood, sweat, tears, and lots of cursing. But it finally started to budge, and then came loose.
    This handy little tool is what made it possible...
    http://www.sears.com/shc/s/p_10153_1...0070921x00003a
    I ran my finger around the edges of the mating surface to feel if it was ok, and a black, torn gasket fell out. There's already a red one in the purolator in my hand, so I guess the guy who changed my oil previously didnt check for the old gasket when he removed the old filter... because this black gasket fits directly over the red one on the purolator.
    Yay for inheriting other people's mistakes!
    Question is, there's no gasket that's supposed to be in the mating surface on the car, is there? Whatever fell out of there has to be from an old filter, right?
  13. #13 Re: Really need some help, stuck oil filter
    Delaware, OH
    yep. Only gasket supposed to be there is the rubber Oring on the oil filter. And when you put the new filter on you only go a little past hand tight
    No More GTP for me.
  14. #14 Re: Really need some help, stuck oil filter
    Apr 2009
    stockton ca
    i go hand tight plus half turn
  15. #15 Re: Really need some help, stuck oil filter
    Pennsylvania
    Well, it's all full of oil and running fine now.
    Thank you guys so much for helping out someone with the most noobish things imaginable
    Your patience is appreciated.
  16. #16 Re: Really need some help, stuck oil filter
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    thats freakin crazy man. my grandpa introduced me to that exact tool for the first time in my life just last weekend. amazing invention! he uses his to take the 8 inch wide oil filter off this john deere tractor. his has a slot on the end where a 3/8 inch drive socket wrench fits in
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  17. #17 Re: Really need some help, stuck oil filter
    SE Level Member Lionel's Avatar
    Moncton N.B.
    that story reminds me of when i work on cars, anything that can go wrong usually does... It's nice working on an 04 though, less rust...
    glad you got it off dude! good job!
  1. 04+ HUD is stuck...
    By PonchoDvr4Lfe in forum General Tech Discussion
    Last Post: 02-22-2012, 01:55 PM
  2. oh its stuck
    By ChdMcD in forum General Tech Discussion
    Last Post: 04-17-2010, 06:50 AM
  3. This is what im stuck with...
    By TorqueAutoMotiv in forum The Rant Forum
    Last Post: 09-11-2009, 09:39 PM
  4. what im stuck with
    Last Post: 07-20-2009, 05:31 PM
  5. stuck in a rut
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2009, 12:50 AM
