Thread: needs advice: SS m0 kit vs Top Swap
Page 1 of 3 123 LastLast
Results 1 to 20 of 57
  1. #1 needs advice: SS m0 kit vs Top Swap
    GT Level Member uNda6gT's Avatar
    Jan 2009
    Baltimore
    Hey everybody I'm not sure what direction I wanna go with supercharging my car. I have some1 selling me a almost complete top swap (m90,lim,heads,fuel rails) for $450,then I have someone selling me a ssm90 for $700. I'm willing to put around $2000 into this project. My issue is I really have no 1 in my area to help me top swap my car and it just seems pretty difficult, I see a lot of people bash zzp's ssm90 kit when compared to the top swap,basically I just wanted some advice on what to do in this situation. Basically a what would you do question. Thanks!
    02 Pontiac Grand Prix GT:Intake,SLP Powerflo Catback,HV3,DHP PCM, 15.3 @89mph
    96 z28 Geared Stalled Bolt On......Typical
  2. #2 Re: needs advice: SS m0 kit vs Top Swap
    Jul 2008
    Germantown, Maryland
    Go turbo! haha
    How ya been, man?
  3. #3 Re: needs advice: SS m0 kit vs Top Swap
    Top Swap...WITH headers...and a custom tune, ported blower/TB, rockers, and a 3.5"/3.6"
  4. #4 Re: needs advice: SS m0 kit vs Top Swap
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The difference between a top swap and the SSM90 comes down to two things, the heads and the harmonic balancer. Do some research, if you feel you can swap those two things, definitely go with the top swap. Virtually everything else gets changed in both setups, and you're going to have everything off down to the heads anyway.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: needs advice: SS m0 kit vs Top Swap
    Also...if you have the coin...get at LEAST the exhaust ports done on the heads...you for SURE won't regret it. Letting that thing breathe is the key to power.
  6. #6 Re: needs advice: SS m0 kit vs Top Swap
    Jan 1970
    Maquoketa, Iowa
    The SSm90 was developed as a cheaper route to supercharge a L36. Now that everything is a lil cheaper, its just a question of how much labor you want to do. The whole top swap will be better in the end, but its more labor.
    On the other hand, you may just want to go turbo... A z3 kit will make you more than happy, make more power than a top swap and more fun to drive. The hardest part in installing a simple turbo or at least the Z3 kit is unbolting the factory downpipe and crossover.
  7. #7 Re: needs advice: SS m0 kit vs Top Swap
    Jan 2009
    Baltimore
    thanks guys for all of the advice. lol i would go turbo but scared of what it might do to the tranny...now im really leaning towards the top swap ported n polished,headers,ssic,custom tune,or rockers instead of ssic
  8. #8 Re: needs advice: SS m0 kit vs Top Swap
    Jan 2009
    Baltimore
    Quote Originally Posted by Quicklynx View Post
    Go turbo! haha
    How ya been, man?
    hey man long time no hear! lol do you still live in maryland? because if you do could you still lend a hand in the top swap?
  9. #9 Re: needs advice: SS m0 kit vs Top Swap
    Don't waste your money on a SSIC...you can do better with Methanol Injection and don't have to worry about a warping core.
  10. #10 Re: needs advice: SS m0 kit vs Top Swap
    Banned - Busted For Scamming
    Feb 2009
    Just get a phenolic intercooler.
  11. #11 Re: needs advice: SS m0 kit vs Top Swap
    Topeka, KS
    Quote Originally Posted by uNda6gT View Post
    A turbo won't put any more harm on your tranny than a top swap will. It all maters how you drive it too.
    If you got 2k to spend go Turbo!
  12. #12 Re: needs advice: SS m0 kit vs Top Swap
    Grand Island, Nebraska
    or do the top swap and use your leftover money for tranny parts.
  13. #13 Re: needs advice: SS m0 kit vs Top Swap
    Apr 2009
    stockton ca
    do the top swap and head work ,headers save the extra cash for when the trans goes
  14. #14 Re: needs advice: SS m0 kit vs Top Swap
    Feb 2009
    Turbo!!
  15. #15 Re: needs advice: SS m0 kit vs Top Swap
    Quote Originally Posted by rynoman03 View Post
    yes it will.
  16. #16 Re: needs advice: SS m0 kit vs Top Swap
    Jan 1970
    Maquoketa, Iowa
    Actually I kinda doubt a basic turbo kit will destroy the tranny. As long as the tranny is mechanically sound now, 6-8psi non intercooled would be safe enough. It would have more power than a topswap, and easily upgradeable to run 12's/11's if wanted. I've been running on my stock tranny for almost a year now on 12psi intercooled E85. As long as you don't drive stupid it should last. The great thing about turbo is the lag, for these trannies, its just enough time to let the tranny shift before pulling very hard.
  17. #17 Re: needs advice: SS m0 kit vs Top Swap
    i figured the extra 100 ft lbs of torque you made between the low end and full spool would put a large shock load on the transmission which is what kills it in the end anyway.
  18. #18 Re: needs advice: SS m0 kit vs Top Swap
    Feb 2009
    Hell the shock load from punching it with the m90 seems more of a stress then turbo and hasnt led to problems yet with me.
  19. #19 Re: needs advice: SS m0 kit vs Top Swap
    GT Level Member ChrisGTT's Avatar
    Nov 2008
    NY
    These posts made me laugh. You guys just made my night lol
    Ok the amount of stress that whipping a M90 into full boost progressively on most setups isn't even comparable to the amount of force jumping into boost on a turbo.
    You're forgetting that 10psi out of an M90 is much different then 10psi out of even a small turbo like a 61.
    Turbo v. Positive displacement S/C are two totally different animals.
    Look into it:
    http://www.turbobygarrett.com/turbob...ch_center.html
    Anyways to the op
    How confident are you in your wrenching ability?
    Top swap would be the way to go because it give you room to expand. With the SSm90 kit you become limited such as I/C size and the single belt setup is eh.
    It all depends how far you want to go.
    Speed is an addiction the faster you go the slower it becomes.
    01 GT | Matt's new TT cam | PT-67 | 18-22psi and a couple stock trannys.
  20. #20 Re: needs advice: SS m0 kit vs Top Swap
    Jul 2008
    Still in MD, let me know if you need the help. My brother just got some space in Hagerstown.
  1. 98 GTP L67 to L32 swap advice
    By jamjam in forum General Tech Discussion
    Last Post: 10-17-2010, 11:49 PM
  2. Need some advice...
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-01-2010, 04:52 AM
  3. swap advice
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 09:28 PM
  4. hello, i'm new here and i am looking for advice
    By millfire517 in forum General Tech Discussion
    Last Post: 03-04-2009, 06:45 PM
  5. Advice.. New Car...
    By Vespers47 in forum Off Topic Discussion
    Last Post: 02-02-2009, 05:33 PM
