Thread: needs advice: SS m0 kit vs Top Swap
Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
  1. #41 Re: needs advice: SS m0 kit vs Top Swap
    Ported blower might help blur the line a little.
  2. #42 Re: needs advice: SS m0 kit vs Top Swap
    GT Level Member uNda6gT's Avatar
    Jan 2009
    Baltimore
    Ok so I finally got all the parts(except the harmonic balancer) now I gotta order
    -zzp top swap gasket set
    -1.9 rockers
    -180° tstat
    -SSAC headers(do I still need downpipe?)
    -still debating between PRJ Wires vs ZZP wires...
    -autolite 104's
    -canned or custom tune
    Am I missing anything guys?
    02 Pontiac Grand Prix GT:Intake,SLP Powerflo Catback,HV3,DHP PCM, 15.3 @89mph
    96 z28 Geared Stalled Bolt On......Typical
  3. #43 Re: needs advice: SS m0 kit vs Top Swap
    Get parts store wires with a lifetime warranty. THE END on that one...
    downpipe comes with the headers.
  4. #44 Re: needs advice: SS m0 kit vs Top Swap
    in a house
    And the 180* t-stat will do nothing except hurt fuel economy.
  5. #45 Re: needs advice: SS m0 kit vs Top Swap
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by silverstreak View Post
    What?
  6. #46 Re: needs advice: SS m0 kit vs Top Swap
    Quote Originally Posted by Bedwards View Post
    What?
    its true. unless youre going for a fairly well equipped setup a lower temperature thermostat doesnt really help and just causes a loss in mileage.
  7. #47 Re: needs advice: SS m0 kit vs Top Swap
    define fairly well equipped? Cam qualify for that?
  8. #48 Re: needs advice: SS m0 kit vs Top Swap
  9. #49 Re: needs advice: SS m0 kit vs Top Swap
    180* t-stat it is then.
  10. #50 Re: needs advice: SS m0 kit vs Top Swap
    Jan 2009
    Baltimore
    Quote Originally Posted by uNda6gT View Post
    -1.9 rockers
    -180° tstat
    -autolite 104's
    Can I run a 3.5 pulley with this setup?
  11. #51 Re: needs advice: SS m0 kit vs Top Swap
    Charles City, IA
    Have to tune it with a stock pulley first. See if you have knock. Timing>boost
    SMGPFC Two Nipple General
  12. #52 Re: needs advice: SS m0 kit vs Top Swap
    Your missing the fact that dropping pulley sizes isn't where the power gains is. It is the flow and timing. You can run more timing on a 3.8" pulley and go faster than a 3.5" pulley car that is knocking or with well less timing.
  13. #53 Re: needs advice: SS m0 kit vs Top Swap
    Jan 2009
    Baltimore
    ohh ok I see, that makes sense.I just wish i had a custom tuner in my area but stock 3.8 mps it is for now...
  14. #54 Re: needs advice: SS m0 kit vs Top Swap
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Hey was just wondering, did you complete your top swap yet?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  15. #55 Re: needs advice: SS m0 kit vs Top Swap
    Jan 2009
    Baltimore
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    no not yet, tryna get my money up for some headers....well i have the money just need help with the swap. I see your in the area we should meet up
  16. #56 Re: needs advice: SS m0 kit vs Top Swap
    Bowie, MD
    Exactly what i was gonna say. I have been wanting to top swap for the longest until i found out that i have to get an 04+ tranny for everything to work right because my impala is a 2000. I recently decided to just do a complete l67 engine+tranny swap. I also have the money ready but i need help installing them and tuning. We should definetly meet up tho. I'll pm you my info.
  17. #57 Re: needs advice: SS m0 kit vs Top Swap
    Top swap means keeping your factory tranny.... as well as your factory short block.
    You shouldn't have ANY issues swapping on either an l67 or l32 top end.
  1. 98 GTP L67 to L32 swap advice
    By jamjam in forum General Tech Discussion
    Last Post: 10-17-2010, 11:49 PM
  2. Need some advice...
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-01-2010, 04:52 AM
  3. swap advice
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 09:28 PM
  4. hello, i'm new here and i am looking for advice
    By millfire517 in forum General Tech Discussion
    Last Post: 03-04-2009, 06:45 PM
  5. Advice.. New Car...
    By Vespers47 in forum Off Topic Discussion
    Last Post: 02-02-2009, 05:33 PM
