Thread: ICM Problems??
Results 1 to 20 of 27
  1. #1 Re: ICM Problems??
    Hoffman/Schaumburg, IL
    Yeah, I'm gonna try to clean the contacts in my ignition switch, maybe it is causing the problem, cause sometimes it seems like the power steering is a little screwy
  2. #2 Re: ICM Problems??
    hangover park IL, in the garage working on one of 12 3800's
    just curious but hows your charging system?
  3. #3 Re: ICM Problems??
    14.75volts solid, 3 month old battery, just cleaned the terminals.... My ignition switch was carbon-coated... but I still have my problem
  4. #4 Re: ICM Problems??
    But my Alt, may be outputing a low current, I just don;t have equipment to test it I.e. an inductive amp meter
  5. #5 Re: ICM Problems??
    you can have it tested in car at an autozone but i also have a clamp on inductive probe...
  6. #6 Re: ICM Problems??
    When I turn on all accesories, Ac on 5 and rear defroster on, radio on, headlamps on, the car acts the same, so it must be ok..... I think I'm gonna try some seafoam tomorrow and maybe injector cleaner we will see
  7. #7 Re: ICM Problems??
    Saraland Alabama
    Quote Originally Posted by 02BlueGT View Post
    get it tested anyway, it's free, turning all the accessories on doesn't give a constant load like you would think
  1. starting problems
    By redgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 12:24 AM
  2. HUD Problems
    By 03GTPFour in forum General Tech Discussion
    Last Post: 03-09-2008, 10:38 PM
  3. HID problems...Looking for answers
    By GeddyLee in forum General Tech Discussion
    Last Post: 03-09-2008, 09:22 AM
  4. Starting Problems
    By SahotaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2008, 01:38 AM
  5. Trans problems.
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 07:24 AM
