Thread: ICM Problems??
Results 1 to 20 of 27
  1. #1 Re: ICM Problems??
    Saraland Alabama
    Quote Originally Posted by 02BlueGT View Post
    When I turn on all accesories, Ac on 5 and rear defroster on, radio on, headlamps on, the car acts the same, so it must be ok..... I think I'm gonna try some seafoam tomorrow and maybe injector cleaner we will see
    get it tested anyway, it's free, turning all the accessories on doesn't give a constant load like you would think
  2. #2 Re: ICM Problems??
    hangover park IL, in the garage working on one of 12 3800's
    might as well get it tested for current/voltage under a carbon pile load...just to be sure.
    for the injectors, get yourself some new Orings and pull the rails off. disable the coils (i usually pull the coils and leave the ICM plugged in) flip the rail over and reconnect the inj clips. have a friend crank the car over and look at your injector spray patterns, if you find anything funky, remove the inj connector and clip and flip the inj around (one at a time) reconnect the wires and crank it to try to backflush the injectors, for the most part its a 50/50 shot as to whether that gets rid of the crud that could be causing a streaming injector, but its cheaper than just sendiung them out to be cleaned.
  3. #3 Re: ICM Problems??
    Hoffman/Schaumburg, IL
    I think I just need to buy a top swap, and replace everything ....I need to drive it now that the ignitio0n switch is clean, the pcm may need to relearn???... I am leaning back towards vacuum issue, cause the needle is very shaky and moves between 19 and 20.5 inches
  4. #4 Re: ICM Problems??
    did you remove and plug the evap purge solenoid? small changes like that could just be the system purging the vapor cannister.
    block it off at the TB and retest vac
    gonna get trannymans setup?
  5. #5 Re: ICM Problems??
    Yeah, I've been emailing him, I think I just gonna do it.
    The evap is not causing the problem, unplugged it, then capped of the vac line, no change
  6. #6 Re: ICM Problems??
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    subscribing because I have a similar problem as stated in your other thread.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  7. #7 Re: ICM Problems??
    the engine needs air,fuel and spark.
    ruled out spark (aside from hard to diagnose EMI)
    rulled out a majority of possible air issues
    that leaves fueling pull the injectors i'd bet one is partially cloged/streaming
  8. #8 Re: ICM Problems??
    sorry
  1. starting problems
    By redgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 12:24 AM
  2. HUD Problems
    By 03GTPFour in forum General Tech Discussion
    Last Post: 03-09-2008, 10:38 PM
  3. HID problems...Looking for answers
    By GeddyLee in forum General Tech Discussion
    Last Post: 03-09-2008, 09:22 AM
  4. Starting Problems
    By SahotaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2008, 01:38 AM
  5. Trans problems.
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 07:24 AM
