Thread: HV3 High Velocity intake insert
Results 1 to 20 of 23
  1. #1 HV3 High Velocity intake insert
    MA
    Project for this weekend.Just before I start does any one have this and does anyone know if the insert just sits in (after i remove the stock runners)and the gasket goes on top (just like the photo)Or will it be self-explanatory when I have it apart these come as two separate pieces?
    below is in two pieces gasket is same on both sides
  2. #2 Re: HV3 High Velocity intake insert
  3. #3 Re: HV3 High Velocity intake insert
    GTP Level Member Scimmia's Avatar
    QCA, IA
    You remove the stock runner, stick the HV3 in in their place, and reinstall like normal, with the gasket between the UIM and LIM.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: HV3 High Velocity intake insert
    Kansas
    On the gasket i had these little clips that were suppose to hold this tube in place.. does anyone know what to do with the tube?
    SOLD 1999 GT Silvermist TS
  5. #5 Re: HV3 High Velocity intake insert
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by Gafford44 View Post
    I keep mine in a box with the old intake gasket
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  6. #6 Re: HV3 High Velocity intake insert
    Dec 2008
    Lawndale, CA
    On my 99 I trimmed the clips from the gasket that held the tube and left the tube off. Have had it this way for almost a year now.
  7. #7 Re: HV3 High Velocity intake insert
    MA
    Got it in anyone can check out some pics on my photobucket:2001 Pontiac Grand Prix GT pictures by KERKER48 - Photobucket
    Everything went well as for that tube I just got it to wedge against the insert and it seems to hold it in really good (I guess we'll see) took it for a quick blast I can't really feel too much of a difference but when I first did my rockers I did not notice too much either at first but then as I drove it more I could notice.I have a U-bend delete still to put in "going tomorrow".Also going to change the resonator at the same time to a magna flow there are two sizes I can get which do you think is better they are both 2.5" in/out 5"x 14" body or 4"x 18" body?
  8. #8 Re: HV3 High Velocity intake insert
    Kansas
    YES!!! thats what i did too. I trimmed the clips and took out the tube.. Im no longer scared.
  9. #9 Re: HV3 High Velocity intake insert
    Wausau, WI
    the longer the better with the res. Why are you replacing the stocker? Unless it is damaged it is a waste of money unless you like rasp and just dont like the stocker.
  10. #10 Re: HV3 High Velocity intake insert
    MA
    There is something loose inside the res. and it rattles that's why i want a new one
    my custom exhaust guy say's a shorter one will be better.Guess I'll wait and see how it sounds going in next Monday.
  11. #11 Re: HV3 High Velocity intake insert
    shorter isnt better on these cars. the catback isnt restrictive and if he thinks it is just slap him for me.
  12. #12 Re: HV3 High Velocity intake insert
    LONGER the resonator the better it sounds
  13. #13 Re: HV3 High Velocity intake insert
    Kansas
    my friend was trying to say that on his grand national he had a glass pack and ran a 11 then he took it off and ran .97 sec faster on his 1/4 mile. Does this make sense?
  14. #14 Re: HV3 High Velocity intake insert
    yes, on a GRAND NATIONAL. not our cars.
  15. #15 Re: HV3 High Velocity intake insert
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    You didn't feel a big difference? Well damn the hv3 is supposed to be THE mod for a gt (and a tune) but anyways..I guess I'm 19362063963% sure I'm top swapping then lol
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  16. #16 Re: HV3 High Velocity intake insert
    Portland Oregon
    Quote Originally Posted by nicksilvergt99 View Post
    when I owned an N/A car I put an HV3 in it. I lost minimal low end, but with shift points at around 6k it really does help at the top end. Makes good with the GT1 cam too after I put the cam in I was running 14.7's.
  17. #17 Re: HV3 High Velocity intake insert
    MA
    I do notice a little difference now but I still have the u-bend in it and they say the more mods you put in the more restrictive the u-bend becomes hopefully when I get rid of that it will help out.
  18. #18 Re: HV3 High Velocity intake insert
    MA
    I also have to take it apart again to get the PCV tube out I don't know what I was thinking it may be disrupting the air flow idk check out link below if you zoom in you can see the tube middle intake hole on bottom.
    2001 Pontiac Grand Prix GT :: HV3 High Velocity Insert picture by KERKER48 - Photobucket
  19. #19 Re: HV3 High Velocity intake insert
    NO crap...its a RWD TURBO car
  20. #20 Re: HV3 High Velocity intake insert
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Do u have any info on that tb spacer?
  1. Where can i find this grill insert?
    By JbrownGTP in forum Visual/Body Modifications
    Last Post: 07-14-2009, 10:40 AM
  2. 1997 GT High Mileage Cold Air Intake
    By Nick22 in forum General Tech Discussion
    Last Post: 06-26-2009, 12:34 AM
  3. High velocity intake insert?
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2008, 10:04 AM
  4. next mod question rocker or intake insert
    By mikeballer124 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2008, 08:49 PM
