Thread: Losing RPM Gauge while driving!
Results 1 to 9 of 9
  1. #1 Losing RPM Gauge while driving!
    Ontario, Canada
    When driving down the highway, I'll lose my RPM gauge but car will still run. However when I shut it off, it often will not start until the car is cold. Any thoughts.
    Prior to replacing my ECM, the car would also shut down completely while driving down the highway.
    Any help appreciated, Thanks in advance.
  2. #2 Re: Losing RPM Gauge while driving!
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    sounds like the ignition control module, or icm that folks talk about on here, its mounted under the coil packs, most auto parts should be able to test them for free. have them test it twice or three times so it gets hot. the rpm guage gets its signal from the icm
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: Losing RPM Gauge while driving!
    Ontario, Canada
    Thanks for the reply, but that is the part I just replaced, that I referred to as the ECM. However problem is still happening, the only difference is the car stays running now instead of shutting down whenever. However when I try to re-start the car it often won't re-start until cold.
    So to recap, current problem consists of car losing RPM gauge while driving and trouble re-starting when I shut it off.
    Thanks for you help.
  4. #4 Re: Losing RPM Gauge while driving!
    Wausau, WI
    crank position sensor?
  5. #5 Re: Losing RPM Gauge while driving!
    Apr 2009
    i would say something somewhere is shorting out. u can try the crank poosition sensor like liquidfire suggests. again the rpm signal comes from the ign control module.
  6. #6 Re: Losing RPM Gauge while driving!
    Is your TCS light coming on when this happens? Mine has the same symptoms. Have to pump the gas to get it to restart. Pretty sure its the CPS from all the research I have done. Basically its going into a sort of limp mode when it happens and only getting partial signal from the cps.
  7. #7 Re: Losing RPM Gauge while driving!
    Ontario, Canada
    Yes, my light is always on including the check tire pressure light, and ABS light. But last time these lights came on it was a wheel bearing sensor, which I replaced at a pretty steep cost. I had the codes read on my car and it is now showing that my other wheel bearing sensor is shot. However bearing is still fine, so for now really trying to fix other problem first in case it is something major. I have to question how much to put into a car that I have over 250,000kms on.
    When I lose my RPM gauge, I will feel a jerk in the car and then everything is fine, until I shut it off. Then I sometimes (not always) have trouble starting it. Further to that sometimes my check engine light will also come on, but if I keep driving (it will eventually go out) weird.........
  8. #8 Re: Losing RPM Gauge while driving!
    Ontario, Canada
    Thank you to everyone who replied. I finally found the time to change my Crank Position Sensor (CPS) and everything is back to normal and working fine.
    Thank You.
  9. #9 Re: Losing RPM Gauge while driving!
    Wausau, WI
    ha......called it.
  1. what comes to mind when driving?
    By Bio248 in forum Off Topic Discussion
    Last Post: 08-25-2009, 06:27 PM
  2. Beeping while driving
    By boostjunky in forum General Tech Discussion
    Last Post: 02-26-2009, 10:45 PM
  3. Driving Friends GTP
    By GreenPrix in forum Track Sessions and Kills
    Last Post: 11-20-2008, 04:56 PM
  4. This is driving skill!
    By Abrasive in forum Off Topic Discussion
    Last Post: 11-14-2008, 11:02 PM
  5. while driving, BOC!
    By fst in forum The Rant Forum
    Last Post: 02-04-2008, 10:47 AM
