Thread: L36 Coolant Leak
Results 1 to 10 of 10
  1. #1 Re: L36 Coolant Leak
    GTP Level Member Scimmia's Avatar
    QCA, IA
    agrazela did a good write up on this, even if he took it a bit far. I have it bookmarked at home, I'll get you the link after work if you'd like. I did a bunch of research on this, and was planning on making the swap, but decided to to another direction at the last minute. In fact, I still have an adapter and an HV3 sitting around.
    2001 Buick Regal LS - Almost Stock
  2. #2 Re: L36 Coolant Leak
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    That would be awesome if you can get me the write up. I'll probably purchase the adapter off of you but I need to make sure my buddy want to go this direction first.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  3. #3 Re: L36 Coolant Leak
    Schaumburg, IL
    Also is the L26 LIM the same as the L36 LIM
  1. Coolant leak below supercharger
    By dlemmen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2009, 01:15 PM
  2. suspected coolant leak into oil
    By e56505 in forum General Tech Discussion
    Last Post: 02-16-2009, 03:18 PM
  3. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
  4. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
  5. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
