Thread: Top Swap vs SSm90
Results 1 to 20 of 28
  1. #1 Top Swap vs SSm90
    GT Level Member uNda6gT's Avatar
    Jan 2009
    Baltimore
    alright guys,im in a dilemma right now,I got somebody selling me a top swap and some1 selling me a ssM90....I need everybodys opinion on which 1 should I get,the top swap jus needs gaskets and I think a mps and the ssm90 kit needs the zzp billet fuel logs 2 complete the kit,which 1 should I get?
    02 Pontiac Grand Prix GT:Intake,SLP Powerflo Catback,HV3,DHP PCM, 15.3 @89mph
    96 z28 Geared Stalled Bolt On......Typical
  2. #2 Re: Top Swap vs SSm90
    Barksdale AFB, LA
    Top swaps are cheaper, still require tuning, and are a little more difficult to install. The SSM90 kit is more expensive, you still retain your old heads, should come with a tuned PCM, and is easier to install.
    I went the top swap route so I could have the heads rebuilt and cleaned and it's like having a brand new engine. All the parts were perfectly clean going on. If you do go the top swap route, take the heads to a machine shop and get them magnafluxed for cracks to make sure they're good. Our heads have a habit of cracking between the valve seats as they get older if they're not in a taken care of engine.
    No one can tell you which one to do. We can lay you out the options and you decide for yourself.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Top Swap vs SSm90
    Banned - Busted For Scamming
    Feb 2009
    id top swap it. the ssm90 just looks gay to me idk.
    Logan
  4. #4 Re: Top Swap vs SSm90
  5. #5 Re: Top Swap vs SSm90
    Feb 2009
    i know, right; reminds me of the cobalt
  6. #6 Re: Top Swap vs SSm90
    the cobalt only has one belt? hm, another reason NOT to buy one..
  7. #7 Re: Top Swap vs SSm90
    Donating Users chico's Avatar
    I have a combo of the kit and TS,started with SS M-90 then pulled the engine P&P the GT heads added cam and 2 belt setup ,I still have the inj.in the LIM and use ZZP rails ,if I were to start again I would say pull the engine and do a top swap ,it's cheaper than the ss kit and gives you more options,but the SS M-90 kit does work well if your satisfied with say a 3.5" pulley a SSIC and 1.9 rockers this will give you a mid 13sec car for around $1500 .I did design a idler pulley that will help with the 1 belt setup if anyone is interested.Chico.
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  8. #8 Re: Top Swap vs SSm90
    Jersey
    If you want to go cheap and have a fun quick car, get the ssm90 kit.
    If you plan on a bigger build down the road, and your car is an on-going project to go faster, then go top swap.
    Im still getting parts together for mine, you can go real cheap on the top-swap, im kind of anal about parts that go on my car so i opted for alot more and now i think i spent way to much and don't even have the s/c on my car yet.. A good rule of thumb is whatever you plan on spending, double it. Im hitting the $2,500 mark...I should have just gone turbo.
    16' wrx sti- stock
  9. #9 Re: Top Swap vs SSm90
    Feb 2009
    yea the cobalt uses one belt, and it wraps on the SMOOTH pulley to drive the s/c. lol
  10. #10 Re: Top Swap vs SSm90
    Feb 2008
    San Diego, CA
    Quote Originally Posted by chico View Post
    ...I did design a idler pulley that will help with the 1 belt setup if anyone is interested.Chico.
    I am curious to see what you did as far as an idler pulley for a single belt system.
    I started with this plywood prototype:
    And wound up with this:
    (This is in a 1998 H-body; "hybrid" topswap on an L26 block using L67 heads/LIM but the SSM90/MPS pulley system)
  11. #11 Re: Top Swap vs SSm90
  12. #12 Re: Top Swap vs SSm90
    memphis
    That is sexy..
  13. #13 Re: Top Swap vs SSm90
    Jan 2009
    Baltimore
    well doesn't zzp have a tune for people doin a regular top swap? and with the top swap what size pulley would I start with?
  14. #14 Re: Top Swap vs SSm90
    as big of one as you can find. at least the stock one.
    that is, unless youre doing other stuff with it like a cam.
  15. #15 Re: Top Swap vs SSm90
    Jan 2009
    Baltimore
    ok so what mods do I need to put the pulley at a 3.8 or 3.6?
  16. #16 Re: Top Swap vs SSm90
    Barksdale AFB, LA
    Quote Originally Posted by uNda6gT View Post
    I had trouble ironing out a tune with at 3.8" and I have a Plog, DP, intake, 180*, and 1.9 rockers. Plus, I do my own custom tuning. I'd say a good set of headers, an intake, a tune, and the 1.9 rockers or a cam should let you run a 3.8" pretty well. Anything below that and you'll want an intercooler.
    The higher compression of the N/A block works with you to make more power but can also be what destroys your engine.
  17. #17 Re: Top Swap vs SSm90
    Jul 2008
    Germantown, Maryland
    when you get everything together I should be able to help you tune for it.... I will gather more info on it if you are not able to acquire a ZZP tune
  18. #18 Re: Top Swap vs SSm90
    Jul 2008
    agrzela... you selling those?
  19. #19 Re: Top Swap vs SSm90
    Topeka, KS
    Don't do a ZZP tune. They are doomed from the get go! I've seen motors blown from the ZZP tune.
  20. #20 Re: Top Swap vs SSm90
    Jan 2009
    Baltimore
    damn,what would life be like if everything was ez! lol.... guess I will start off with a 4.0 pulley since all I have is intake,exhaust,3inch dp catless,stage1 hv tb and jus work my way up from there
