Thread: Engine temp issue
Results 1 to 4 of 4
  1. #1 Engine temp issue
    Donating User
    Jul 2014
    Minnesota
    So for a few months Ive been having this issue, my coolant temp gauge will sit at about 170-175 degrees, or about 2 small lines above the 160 mark. normally it would sit around 185 mark, my heat still blows but it is not as hot as it has been in the past. I am wondering if this could maybe be an issue with the coolant temp sensor?
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: Engine temp issue
    The Boss Iceman6669's Avatar
    Jun 2011
    Have you checked your gauge with some form of scan tool? Mine was WAY off when I did the 04+ needles.
    2011 F-150 Yote powered
  3. #3 Re: Engine temp issue
    Donating User
    Jul 2014
    Minnesota
    I have not, I will check that, thanks
  4. #4 Re: Engine temp issue
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Yeah. Definitely check the gauge. Could also be the thermostat is stuck partially open. Pull your radiator cap off on a cold engine start and if coolant moves, your thermostat is stuck open. But my money is on the gauge or the sensor. Just whatever you do, DON'T buy the aftermarket sensors. I've heard of way too many faulty ones.
  1. temp light issue
    By disblile in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2016, 12:55 PM
  2. Engine Temp Issue
    By dpzelenak in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-15-2016, 01:08 AM
  3. weird temp issue
    By 08 gp lvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2015, 08:23 AM
  4. Temp Light Wiring Issue???
    By disblile in forum General Tech Discussion
    Last Post: 06-29-2010, 05:26 PM
  5. Temp light wiring issue??
    Last Post: 06-28-2010, 10:22 AM
