Thread: weird temp issue
Results 1 to 6 of 6
  1. #1 weird temp issue
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    I searched online with this issue to no luck. My temp sensor was working intermittently so i swapped it out for a gm one. Everything was good for a while but the problem returned, it would happen once in awhile but now it does it all the time and it seldomly works now. I traced back the wires there good, sensor tested good, i remove the battery cable and it works fine for about 20 start ups. My high beams dont work either when temp gauge is out... thoughts??
  2. #2 Re: weird temp issue
    Aug 2013
    arlington, tx
    I'd peel back the wiring loom and trace the wires all the way to the ecm or pcm or whatever you call it under the airbox. Sounds like a bad connection to me. Also check the pigtail going to the sensor. It's weird how your high beams don't work when the temp gauge is out tho.
  3. #3 Re: weird temp issue
    Aug 2013
    arlington, tx
    Here's what I had to go through to find my break in the wire...
  4. #4 Re: weird temp issue
    Nov 2011
    north bay, ontario
    Im gonna have to try something cuz when it dont work and the engine is hot its extremely hard to start. Very strange that my high beams dont work tho when temp gauge is out.
  5. #5 Re: weird temp issue
    Massachusetts
    Please let us know what you find. This one is interesting.
  6. #6 Re: weird temp issue
    Apr 2015
    Muskegon, Mi
    Ignition Switch?
  1. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  2. Weird engine temp problem
    By Rivmage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-08-2011, 06:59 AM
  3. weird car issue
    By NashGT02 in forum General Tech Discussion
    Last Post: 07-29-2010, 09:16 AM
  4. Weird Sub Issue
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-20-2010, 10:11 AM
  5. Weird temp gage problem
    By jokyfo in forum General Tech Discussion
    Last Post: 02-02-2010, 05:06 PM
