Alright, so I've been trying for a long time not to post a question as stupid as this one, but I think I'm not wrapping my head around the PCV system correctly so please humor me. I swapped to a L26 on a series 2 a few thousand miles ago, and I think everything is running fine, but I have no reference since I've never driven a stock working gp. (mine was blown up when purchased).
I read that you have to drill into the side and plug the drilled hole and cap the upper pipe, and others say just put a breather on it. I currently have just a breather so my air isn't pre-metered or anything so I don't know if this causes problems.
I've also seen those who have both and drill/tap the side and have the breather.
From my understanding, the upper breather goes to the pcv valve via a small internal passageway, and that there's another passageway in either the throttle body neck or going to the throttle body directly. My throttle body adapter blocks everything so I want to make sure that I'm not essentially canceling out the pcv system and threatening blowing a gasket.
My other loaded question is I've always been a fan of catch cans, although how our pcv system is set up, there is no stock way to hook one up, and I don't want to do the valve cover breather method.
I've seen some ls guys run a vacuum tubing and run the map sensor external. If that is possible, you could potentially add a tube coming up from where the map sensor used to be. If I'm not mistaken, if you could do this, you could epoxy the ports going to the pcv vacuum and run it to a tapped vacuum port through a catch can. This would give us the functionality of running a catch can finally! I know this would probably be a pointless mod to most and wouldn't help much out, but I really want a catch can cause I'm tired of the sludge that builds up on our throttle bodies!
If anyone has done this or attempted this, please let me know. I'll try to post some pictures to clarify things as I go.
