Thread: Mystery Leak? Lean condition
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 61
  1. #1 Mystery Leak? Lean condition
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Alright, so I'm getting to the point where I might have to break my rule and take my beauty in to the shop.... hopefully someone can help and save me the hassle!
    To preface, the car runs "ok" and has since I got everything rebuilt. However, I've always noticed that it struggles going up hills and doesn't have much "get up and go" which has bothered me.
    I finally had enough time to hook up my scan tool and check things out in detail this weekend. There are NO check engine lights, but after bringing everything up to temperature, I get around 15% lean long term fuel trim at idle and when my foot is off the accelerator, which immediately makes me think vacuum leak.
    The bad is that there is no auditory leak either vacuum or exhaust. The MAP pressure is normal vacuum and responds with throttle accordingly. The fuel pressure is around 55-60 psi and increases to 70 when regulator vacuum is removed or throttle is snapped. MAF sensor is in range and responds as it should (and I just cleaned it). IAT sensor is at correct readings. EGR seems to be functioning correctly. O2 sensors are operating normally. Idle rpm is around 750-800 (I think that's normal).
    I used the propane test EVERYWHERE and no leaks detected. Unfortunately, I don't have access to a smoke machine.
    There isn't excessive crankcase pressure, and no detectable blow-by by removing the oil fill cap.
    Basically, I'm lost... help! lol
  2. #2 Re: Mystery Leak? Lean condition
    what you using to read the fuel trims? t app? whats it actually saying for a reading?
  3. #3 Re: Mystery Leak? Lean condition
    Aug 2017
    Raytown, MO
    It's an off brand scanner, but it's never been wrong on me yet. If anyone is curious, it's by Launch and it's the EasyDiag2.0 (don't think they sell it in the US anymore but it's fantastic). The LTFT read around +15-16% at idle and drop to between -3-+3% when any amount of pedal is applied (I think our cars won't throw P0171 until it's over +-20%) and immediately returns to 15% after pedal is released both at idle and at town and highway speeds, same result.
    I have done some basic mods, but for the most part the engine is stock, so it shouldn't be out of wack.
  4. #4 Re: Mystery Leak? Lean condition
    just so we're clear trim read neg as rich, pos is lean. so a -15 is kinda normal at idle stock tune. -3 cruising is also normal.
    last tune up was? cat still on the car? miles? being na ill lean towards the cat being pooched if over 100,00 miles.
  5. #5 Re: Mystery Leak? Lean condition
    Aug 2017
    Raytown, MO
    Engine rebuilt and running perfect. Catalytic converter brand new along with headers and catback exhaust. It is a high flow cat so it does throw P0420, but this won't affect fuel trim.
    Body mileage is 120,000 but the engine has around 7,000 since the rebuild.
    Name a part, I've probably replaced it. There is literally not a single thing I haven't laid my hands on... lol That's why I'm so stumped....
  6. #6 Re: Mystery Leak? Lean condition
    Aug 2017
    Raytown, MO
    Here's a small snippet of some fuel trim data while I'm driving around town. Tell me what you think! (sorry about the audio) lol
    https://www.youtube.com/watch?v=nPWwf0EJnzQ
  7. #7 Re: Mystery Leak? Lean condition
    that link takes me to my own edit page for yt.
  8. #8 Re: Mystery Leak? Lean condition
    Aug 2017
    Raytown, MO
    lol can you tell I'm new at this? haha let me see if I can fix that
    *Edit* try it now. It should be working.... I think... lol
    Any way to embed videos? I tried but couldn't get it to work.
  9. #9 Re: Mystery Leak? Lean condition
    sorry but that thing sucks. no way i can read it.
  10. #10 Re: Mystery Leak? Lean condition
    Aug 2017
    Raytown, MO
    Lol Sorry. That's what I'm working with. Basically, the ltft is at 15% and goes down when gas is given.
  11. #11 Re: Mystery Leak? Lean condition
    Quincy, Mass
    What was rebuilt on the engine? Top end or pistons etc?
    No more GP 04 Impala SS Indy:
  12. #12 Re: Mystery Leak? Lean condition
    Aug 2017
    Raytown, MO
    Quote Originally Posted by Swiggles View Post
    EVERYTHING! LOL no but really.... every bearing replaced, all clearances back to factory both heads and block. Yes, I replaced all tty bolts and main line honed. 20 thou overbore. New pistons, rings, wrist pins, balanced, all new gaskets. Basically, my engine rebuild is not the problem.
  13. #13 Re: Mystery Leak? Lean condition
    Quincy, Mass
    I was chasing a +16% ltft, did a smoke test and still had no leaks. Ended up being my tune. Where you are mostly stock it could still be the stock tune.
    Also rebuilding these motors usually doesn’t end well. If you are staying close to stock with mods you’ll be fine.
  14. #14 Re: Mystery Leak? Lean condition
    Aug 2017
    Raytown, MO
    What about a stock tune would cause a lean condition? Fuel injectors?
    And I think people's problems and fears with rebuilding these engines is merely they cut corners on the rebuild. I haven't seen a single properly rebuilt engine failure to date, they all admit skipping something along the way. I'm at over 7000 miles with no issues. I'm hoping for many more
  15. #15 Re: Mystery Leak? Lean condition
    If it's tune related it's because you technically increased the size of the engine without telling the computer.
    Ideally you'd add in a couple % to the airflow tables like the MAF curve or Primary VE table. The additional % is how you tell the computer to add more fuel. The more air the engine see the more fuel it will give in a simple terms.
  16. #16 Re: Mystery Leak? Lean condition
    Aug 2017
    Raytown, MO
    Darn. That's what I was afraid of... I'm guessing this would need a dyno tune for this? I'm still confused why if it's the piston size it decreases when I accelerate? Wouldn't this be across the board?
  17. #17 Re: Mystery Leak? Lean condition
    if you went 20 over on the pistons it now sucks in more air, needs more fuel too.
  18. #18 Re: Mystery Leak? Lean condition
    Aug 2017
    Raytown, MO
    Ok. thanks! Good to know! Guessing I'd need a dyno tune? Can't imagine a stock tune would work...
  19. #19 Re: Mystery Leak? Lean condition
    The Boss Iceman6669's Avatar
    Jun 2011
    A dyno could help. But I wouldn’t rule out a street tune with a WB.
    2011 F-150 Yote powered
  20. #20 Re: Mystery Leak? Lean condition
    street tune would be better. if you can find a local with a tuner that would be best, most dyno shops dont tune 3800's.
  1. MAF honeycomb causing lean condition?
    By K Kraziee in forum General Tech Discussion
    Last Post: 04-27-2013, 12:03 PM
  2. lean condition...
    By dieyanks13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2013, 06:52 AM
  3. fixed the p0171 lean condition
    By Erik Adam Rodriguez in forum General Tech Discussion
    Last Post: 01-27-2013, 10:00 PM
  4. GTP lean condition
    By gerhardt02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2009, 07:55 PM
  5. lean condition code
    By TDCRacing in forum PCM Tuning
    Last Post: 05-06-2008, 07:12 PM
