#1
Mystery Leak? Lean condition
12-31-2017
Alright, so I'm getting to the point where I might have to break my rule and take my beauty in to the shop.... hopefully someone can help and save me the hassle!
To preface, the car runs "ok" and has since I got everything rebuilt. However, I've always noticed that it struggles going up hills and doesn't have much "get up and go" which has bothered me.
I finally had enough time to hook up my scan tool and check things out in detail this weekend. There are NO check engine lights, but after bringing everything up to temperature, I get around 15% lean long term fuel trim at idle and when my foot is off the accelerator, which immediately makes me think vacuum leak.
The bad is that there is no auditory leak either vacuum or exhaust. The MAP pressure is normal vacuum and responds with throttle accordingly. The fuel pressure is around 55-60 psi and increases to 70 when regulator vacuum is removed or throttle is snapped. MAF sensor is in range and responds as it should (and I just cleaned it). IAT sensor is at correct readings. EGR seems to be functioning correctly. O2 sensors are operating normally. Idle rpm is around 750-800 (I think that's normal).
I used the propane test EVERYWHERE and no leaks detected. Unfortunately, I don't have access to a smoke machine.
There isn't excessive crankcase pressure, and no detectable blow-by by removing the oil fill cap.
Basically, I'm lost... help! lol
#2
Re: Mystery Leak? Lean condition
12-31-2017
what you using to read the fuel trims? t app? whats it actually saying for a reading?
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#3
12-31-2017
It's an off brand scanner, but it's never been wrong on me yet. If anyone is curious, it's by Launch and it's the EasyDiag2.0 (don't think they sell it in the US anymore but it's fantastic). The LTFT read around +15-16% at idle and drop to between -3-+3% when any amount of pedal is applied (I think our cars won't throw P0171 until it's over +-20%) and immediately returns to 15% after pedal is released both at idle and at town and highway speeds, same result.
I have done some basic mods, but for the most part the engine is stock, so it shouldn't be out of wack.
#4
12-31-2017
just so we're clear trim read neg as rich, pos is lean. so a -15 is kinda normal at idle stock tune. -3 cruising is also normal.
last tune up was? cat still on the car? miles? being na ill lean towards the cat being pooched if over 100,00 miles.
#5
12-31-2017
Here's a small snippet of some fuel trim data while I'm driving around town. Tell me what you think! (sorry about the audio) lol
https://www.youtube.com/watch?v=nPWwf0EJnzQ
#6
12-31-2017
that link takes me to my own edit page for yt.
#7
12-31-2017
Scottydoggs
Engine rebuilt and running perfect. Catalytic converter brand new along with headers and catback exhaust. It is a high flow cat so it does throw P0420, but this won't affect fuel trim.
Body mileage is 120,000 but the engine has around 7,000 since the rebuild.
Name a part, I've probably replaced it. There is literally not a single thing I haven't laid my hands on... lol That's why I'm so stumped....
#8
12-31-2017
Scottydoggs
lol can you tell I'm new at this? haha let me see if I can fix that
*Edit* try it now. It should be working.... I think... lol
Any way to embed videos? I tried but couldn't get it to work.
#9
12-31-2017
sorry but that thing sucks. no way i can read it.
#10
Donating User
12-31-2017
What was rebuilt on the engine? Top end or pistons etc?
No more GP
04 Impala SS Indy:
#11
12-31-2017
Swiggles
EVERYTHING! LOL no but really.... every bearing replaced, all clearances back to factory both heads and block. Yes, I replaced all tty bolts and main line honed. 20 thou overbore. New pistons, rings, wrist pins, balanced, all new gaskets. Basically, my engine rebuild is not the problem.
#12
12-31-2017
Scottydoggs
Lol Sorry. That's what I'm working with. Basically, the ltft is at 15% and goes down when gas is given.
#13
Donating User
12-31-2017
I was chasing a +16% ltft, did a smoke test and still had no leaks. Ended up being my tune. Where you are mostly stock it could still be the stock tune.
Also rebuilding these motors usually doesn’t end well. If you are staying close to stock with mods you’ll be fine.
No more GP
04 Impala SS Indy:
#14
12-31-2017
What about a stock tune would cause a lean condition? Fuel injectors?
And I think people's problems and fears with rebuilding these engines is merely they cut corners on the rebuild. I haven't seen a single properly rebuilt engine failure to date, they all admit skipping something along the way. I'm at over 7000 miles with no issues. I'm hoping for many more
#15
Turbo is the way to go.
01-01-2018
If it's tune related it's because you technically increased the size of the engine without telling the computer.
Ideally you'd add in a couple % to the airflow tables like the MAF curve or Primary VE table. The additional % is how you tell the computer to add more fuel. The more air the engine see the more fuel it will give in a simple terms.
01-01-2018
Darn. That's what I was afraid of... I'm guessing this would need a dyno tune for this? I'm still confused why if it's the piston size it decreases when I accelerate? Wouldn't this be across the board?
#17
01-01-2018
if you went 20 over on the pistons it now sucks in more air, needs more fuel too.
#18
01-01-2018
Ok. thanks! Good to know! Guessing I'd need a dyno tune? Can't imagine a stock tune would work...
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#19
01-01-2018
A dyno could help. But I wouldn’t rule out a street tune with a WB.
2011 F-150 Yote powered
#20
01-01-2018
street tune would be better. if you can find a local with a tuner that would be best, most dyno shops dont tune 3800's.
