Alright, so I'm getting to the point where I might have to break my rule and take my beauty in to the shop.... hopefully someone can help and save me the hassle!
To preface, the car runs "ok" and has since I got everything rebuilt. However, I've always noticed that it struggles going up hills and doesn't have much "get up and go" which has bothered me.
I finally had enough time to hook up my scan tool and check things out in detail this weekend. There are NO check engine lights, but after bringing everything up to temperature, I get around 15% lean long term fuel trim at idle and when my foot is off the accelerator, which immediately makes me think vacuum leak.
The bad is that there is no auditory leak either vacuum or exhaust. The MAP pressure is normal vacuum and responds with throttle accordingly. The fuel pressure is around 55-60 psi and increases to 70 when regulator vacuum is removed or throttle is snapped. MAF sensor is in range and responds as it should (and I just cleaned it). IAT sensor is at correct readings. EGR seems to be functioning correctly. O2 sensors are operating normally. Idle rpm is around 750-800 (I think that's normal).
I used the propane test EVERYWHERE and no leaks detected. Unfortunately, I don't have access to a smoke machine.
There isn't excessive crankcase pressure, and no detectable blow-by by removing the oil fill cap.
Basically, I'm lost... help! lol
