Thread: throwing coolant out of the back of the motor?
Results 1 to 20 of 28
  1. #1 throwing coolant out of the back of the motor?
    Apr 2013
    Smith County, Tennessee
    so late last week i was driving my car home after about a 30 minute drive going 70mph the whole way. i pull off the interstate and i notice my temp rising and i was going through the drive through and heard some strange (new) grinding sounds and saw my temp spike so i shut it off, then had to drive a little more and it ended up blowing all the coolant out and steaming about a mile down the road. i got water in it and made it home. originally thought it was a hung thermostat but it happened again today, not to the point of steaming hot because i only drove about 10 minutes with a 10 minute break in the middle. it has also been using some oil lately...the car is all stock and at 140,365 miles. i have someone that can help me tear down the motor...i plan to replace those pesky plastic boots, all the other boots, hoses, gaskets, seals, plugs and wires...i plan to possibly build it up some but nothing big at all..anyone have any info on what could be going on? and also what would be a couple small things i can do in the process to make her run better after? really need some hope because i plan to do this teardown as soon as my buddy gets a couple days. thank you!
    05 GP base, audio only. Things coming in time.
  2. #2 Re: throwing coolant out of the back of the motor?
    trace the wet spots back to the engine. wheres it hitting the floor?
  3. #3 Re: throwing coolant out of the back of the motor?
    Apr 2013
    its been splattered everywhere, really haven't been able to locate an exact spot yet. but it has all been on the passenger side between the battery and firewall
  4. #4 Re: throwing coolant out of the back of the motor?
    GTP Level Member
    Oct 2014
    A lot of culprits in that area.
  5. #5 Re: throwing coolant out of the back of the motor?
    Quote Originally Posted by Cruz View Post
    upper coolant elbow then. it blows coolant all over the pass side inner fender.
  6. #6 Re: throwing coolant out of the back of the motor?
    Apr 2013
    i'm looking to tear the block down and replace the upper and lower radiator hoses, heater hose, intake manifold gasket, thermostat, and those little plastic boots...will these work? https://www.amazon.com/gp/product/B0...=AYUN1EXO5XQB3
    or should i use these? https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
    also how are
    NGK 3403 NGK G-Power Platinum Spark Plug TR55GP plugs?
    also need to do something about a new sound in the front end when i'm turning, worse when i'm turning into a small incline
    thank yall for the help..also had my f250 throw both batteries today, and my cummins fan assembly is going crazy
  7. #7 Re: throwing coolant out of the back of the motor?
    GTP Level Member
    Oct 2014
    Either of those elbows will work. I used dorman. Stay away from platinum plus in a 3800. Use iridium or copper. Depends on how often you want to do it.
  8. #8 Re: throwing coolant out of the back of the motor?
    GTP Level Member
    Oct 2014
    Plugs
  9. #9 Re: throwing coolant out of the back of the motor?
    Oct 2013
    Clovis, California USA
    For what it's worth, RTV on the coolant elbows has caused me problems when using Dorman elbows. I took the belt tensioner back off and replaced the Dorman elbows with GM elbows plus silicone grease instead of RTV. I had to scrub all the RTV out with Scotch-Brite and mineral spirits. I can't tell you for sure whether the problem was the Dorman elbows or the RTV, but I'm not using RTV no more.
  10. #10 Re: throwing coolant out of the back of the motor?
    GTP Level Member
    Oct 2014
    Just make sure what ever elbows you use. Clean up the holes very well and lube the o rings a lot.
  11. #11 Re: throwing coolant out of the back of the motor?
    May 2008
    Schuyler, NE
    I always put rtv on Dorman elbows.
  12. #12 Re: throwing coolant out of the back of the motor?
    Topeka, KS
    ^^ I can't say that I've ever done that.
  13. #13 Re: throwing coolant out of the back of the motor?
    GTP Level Member
    Oct 2014
    ^^^x2. Use vaseline or dielectric grease
  14. #14 Re: throwing coolant out of the back of the motor?
    May 2008
    Schuyler, NE
    Lubricating the o-rings can cause them to back out.
  15. #15 Re: throwing coolant out of the back of the motor?
    Oct 2013
    ^ Well, for me it sure helped me slide the elbows in easier. I don't know how you do yours, but I try to slide both elbows in at the same time and then immediately line up the 3 bolts in their holes for the tensioner assembly. If the elbows are clocked right, they'll pull in as the bolts pull the tensioner in. Grease makes all of that go smoothly. For the record, I like using the Dow Corning 111 grease. It's a high viscosity silicone grease that stays where you put it. I apply it to both the elbows as well as the holes they're going into.
  16. #16 Re: throwing coolant out of the back of the motor?
    May 2008
    Schuyler, NE
    Well of course grease helps it slide in....it also helps slide out.
    Which is one reason I use rtv.
  17. #17 Re: throwing coolant out of the back of the motor?
    Nov 2011
    NY
    Never had to use RTV, clean the holes out good, that's it, done, never a leak other than putting in the elbow and pinching the o-ring, so replaced the o-ring and never a leak. Ever... For $8, it's a maintenance sites if you haven't changed them in say, 50k, swap em out and have no worries.
  18. #18 Re: throwing coolant out of the back of the motor?
    SWPA
    Absolutely no need to rtv the orings on the elbows. The lube helps them slide in and they will not slide out once the tensioner is bolted up.
    I've always just lubed the orings with coolant, and the only problem I ever had with the Dorman elbows was when one split on me. Never had a problem with the orings seeping.
  19. #19 Re: throwing coolant out of the back of the motor?
    May 2008
    Schuyler, NE
    It's going to depend on the amount of corrosion and pitting the holes have. O-rings won't seal consistently in all situations. The usage of the aluminum elbows we have now will make it worse.
    I'm not saying that the elbow will fall out once the bracket is bolted into place, but the elbows can move around. The less they move, the less chance you have for a leak.
    Using rtv solves all of these problems.
  20. #20 Re: throwing coolant out of the back of the motor?
    Oct 2013
    ^ If RTV works for you, more power to you. Myself, I'm not ever doing that again.
  1. How to relocate your coil pack to the back side of your motor for 97+ n/a
    By Travisgt2 in forum How To Write-Ups/Tech Tips
    Last Post: 06-09-2016, 04:50 PM
  2. Coolant not Comming Back From Overflow Bottle
    By SATAMAN in forum General Grand Prix Discussion
    Last Post: 01-29-2015, 04:21 PM
  3. seat motor wont go back or forward now only up/down
    By titanfan12 in forum Visual/Body Modifications
    Last Post: 07-12-2013, 11:00 AM
  4. Blower motor resistor, Coolant leak?
    By Jomamma in forum General Tech Discussion
    Last Post: 03-27-2013, 03:06 PM
  5. A/C motor or out of coolant?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-15-2012, 02:25 PM
