Thread: throwing coolant out of the back of the motor?
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: throwing coolant out of the back of the motor?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    ^ didn't use RTV or lube when I did mine, they've held up for 10k miles and 2 removals/re-installations... not a drop of coolant from them.
    I'm also not terribly careful when I do engine work, mostly because I'm usually in a hurry. Just double check what you're doing when you have a few seconds in between one part and the next, and you'll (hopefully) prevent yourself from getting it all the way back together before finding a problem...or maybe prevent a potential problem from happening in the first place.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #22 Re: throwing coolant out of the back of the motor?
    Apr 2013
    Smith County, Tennessee
    ok so i think i'm going to order these https://www.amazon.com/Dorman-47065H...ype=automotive
    and i am not going to use any rtv or anything. i will clean it really well like advised. i have a 2005 base model, these will fit? i understand they are only $10 but every day makes a difference because all 3 of my vehicles went down within the last week. this is the cheapest but most work. the cummins needs a fan bearing and assembly...so that must wait. and thank everyone for the response, haven't gotten feedback like this in a thread on here or cummins forum yet so thank you all!
    05 GP base, audio only. Things coming in time.
  3. #23 Re: throwing coolant out of the back of the motor?
    Apr 2013
    also has anyone had a small rattle under the car from a loose exhaust? i lost one of the little loops that holds onto the hook down there and have had rattle for a while now, and also i had a PO420 code but when all this stuff started happening it went away. had the codes for multiple years and i'm ready to cut it off and straight piping it or something else..very tires of these things happening.
  4. #24 Re: throwing coolant out of the back of the motor?
    GTP Level Member
    Oct 2014
    Rubber exhaust hangers are like 2 bucks. Throw one back on.
  5. #25 Re: throwing coolant out of the back of the motor?
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I use rtv on my coolant elbows as well, never a leak. They feel way too loose in there for my liking without it.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  6. #26 Re: throwing coolant out of the back of the motor?
    Oct 2013
    Clovis, California USA
    Quote Originally Posted by Cruz View Post
    Don't do that! You need to lube the O-rings with something even if it's dielectric grease.
  7. #27 Re: throwing coolant out of the back of the motor?
    never used rtv, just clean the holes well, then oil the o rings and slide em in, get all 3 bolts in but before you snug the first bolt down make sure the top elbow is square looking between the lim and bracket. you do have a little wiggle room.
  8. #28 Re: throwing coolant out of the back of the motor?
    Apr 2013
    awesome, i got the elbows and radiator hoses in from amazon. hoses look a little bit smaller but the inner diameter should be the same. i used gates hoses. the dorman elbows look good and i can't wait to get them installed and see if that fixes my problem. also going to order an LIM gasket i think also before i do the teardown. i will do the grease but i'm not using rtv. any advice before i attempt anything? and thank yall so much!
  1. How to relocate your coil pack to the back side of your motor for 97+ n/a
    By Travisgt2 in forum How To Write-Ups/Tech Tips
    Last Post: 06-09-2016, 04:50 PM
  2. Coolant not Comming Back From Overflow Bottle
    By SATAMAN in forum General Grand Prix Discussion
    Last Post: 01-29-2015, 04:21 PM
  3. seat motor wont go back or forward now only up/down
    By titanfan12 in forum Visual/Body Modifications
    Last Post: 07-12-2013, 11:00 AM
  4. Blower motor resistor, Coolant leak?
    By Jomamma in forum General Tech Discussion
    Last Post: 03-27-2013, 03:06 PM
  5. A/C motor or out of coolant?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-15-2012, 02:25 PM
