Thread: GT motor into GTP
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #1 Re: GT motor into GTP
    Quote Originally Posted by IKeelULotz View Post
    trying to swap the flex plate ritght now and 2 of the bolts dont wanna go in, ive turned it every which way and 2 of them never wanna go in with out effin something up. i noticed there are little placed that line up with the plate, and have lined them up. and tried turning it 180 but they dont seem to line up. ive read on other forums and such that the fly wheel has to be balanced to the motor or you could mess up your crank, bearings, ect. is that true?
    if you look close the bolt pattern is off a bit, like two bolts are further apart then the rest.
    they need to be lined up right or it will vibrate like a muther.
  2. #2 Re: GT motor into GTP
    Sep 2015
    Skiatook, ok
    Here is where im currently at. I got the flex plate on correctly. Got my pcm back from zzp. So all im needing currently is gaskets, throttle body adapter, and some time.
  1. 98 GTP motor to 2002 SE body that had a 3100 motor
    By alenw62 in forum General Tech Discussion
    Last Post: 05-15-2016, 01:40 PM
  2. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
  3. Blower fan wont turn off with motor running , stops with motor off
    By bosull in forum Introductions/Noob Questions
    Last Post: 04-20-2012, 07:32 PM
  4. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
