if you look close the bolt pattern is off a bit, like two bolts are further apart then the rest.
they need to be lined up right or it will vibrate like a muther.
Here is where im currently at. I got the flex plate on correctly. Got my pcm back from zzp. So all im needing currently is gaskets, throttle body adapter, and some time.
