Thread: GT motor into GTP
Results 1 to 20 of 22
  1. #1 GT motor into GTP
    Sep 2015
    Skiatook, ok
    Im dropping a 98 gt motor into a 99 gtp. the gtp split the piston in half because the previous owner is an idiot. Anyway i got the GT motor for free and it runs strong so thats why its going into the gtp. I plan on top swapping it later with a series 3 GTP top end when i have more time. everything should bolt up correctly if i have done my research right. just wanna double check with some folks who have more experience than me
  2. #2 Re: GT motor into GTP
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    PCV stuff will be different I think. Anyone confirm?
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  3. #3 Re: GT motor into GTP
    Buffalo
    Wby not swap the top end to the l36 before install?
  4. #4 Re: GT motor into GTP
    Sep 2015
    Skiatook, ok
    Because i'm broke from buying Christmas stuff lol. But i also dont know if the trans is any good yet either. the guy that had the car before me is an idiot. to give you an idea he forgot a lower intake gasket on the gtp enigne....
  5. #5 Re: GT motor into GTP
    Buffalo
    Oh
    Well if it were me, I would take both engines and swap the l67 stuff to the l36 IF the heads aren't damaged
  6. #6 Re: GT motor into GTP
    Sep 2015
    Skiatook, ok
    well i have everything from the heads up off a gen 3 gtp comp g including the supercharger. besides if i wait i can make sure everything is done right instead of rushing it. but next time the motor comes out im doing a cam and E85
  7. #7 Re: GT motor into GTP
    Buffalo
    Ok
    I guess I was thinking if you had both engines out, you can easily take the gtp parts off and put them.on the gt engine.
    The series 3 supercharger and intake manifold could go on later when you get those parts since you plan on doing a cam
    That way it's pretty much the same engine, same tune until you swap superchargers and cams
  8. #8 Re: GT motor into GTP
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    If you're trying to just get it on the road, drop the L36 in there.
    I hope you have a tuner...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  9. #9 Re: GT motor into GTP
    Buffalo
    Quote Originally Posted by WarStryker13 View Post
    Sigh...
  10. #10 Re: GT motor into GTP
    Sep 2015
    Skiatook, ok
    already have the pcm on the way to zzp
  11. #11 Re: GT motor into GTP
    Buffalo
    What's a pcm go for? Cheaper then some gaskets?
  12. #12 Re: GT motor into GTP
    you need to swap the l67 flex plate or the the tc wont bolt up right. bolt pattern is not the same. the fuel lines wont reach right, but can be dealt with. evap is on the front, vs the rear of the gtp, so longer pig tail (cut and splice more wire) or move the evap. the map sensor, you need a l36 pig tail swapped in place of the gtp's.
    other then those things its a direct swap.
  13. #13 Re: GT motor into GTP
    GTP Level Member
    Oct 2014
    This?
  14. #14 Re: GT motor into GTP
    Buffalo
    But hey it's simpler
  15. #15 Re: GT motor into GTP
    Quote Originally Posted by CrazyGuy03 View Post
    right lol no way id just drop a l36 in, its out and it sounds like you got the top swap parts already, so buy head gaskets and do it now. you should be doing the lim gaskets on the l36 anyways. whats two more gaskets and new bolts?
  16. #16 Re: GT motor into GTP
    Buffalo
    I could only lead a horse to water .....
  17. #17 Re: GT motor into GTP
    Sep 2015
    Skiatook, ok
    well, i guess i might as well. ill have to get payed again and email zzp and have tell them to change the tune. I do have the heads and all from a 05 gtp, i guess i would buy head gaskets for a 05 gtp?
  18. #18 Re: GT motor into GTP
    the only other thing you should get is headers. or tell zzp your running stock manifolds. headers will help a ton tho.
  19. #19 Re: GT motor into GTP
    Sep 2015
    Skiatook, ok
    good thing the car already has full exhaust
  20. #20 Re: GT motor into GTP
    Sep 2015
    Skiatook, ok
    ive read on other forums and such that the fly wheel has to be balanced to the motor or you could mess up your crank, bearings, ect. is that true?
  1. 98 GTP motor to 2002 SE body that had a 3100 motor
    By alenw62 in forum General Tech Discussion
    Last Post: 05-15-2016, 01:40 PM
  2. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
  3. Blower fan wont turn off with motor running , stops with motor off
    By bosull in forum Introductions/Noob Questions
    Last Post: 04-20-2012, 07:32 PM
  4. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
