Thank you GP Manter, so we ended up doing the Tstat and rtv with it. Now in cold weather even the last few winters I noticed the heat not so warm, the t stat was changed in 2015, hooked it up to a scanner, and it runs around 79 C (174 f) 81 C (177 F) degrees celsius on the highway in cold weather, -1 C. While the Tstat is a 195 F.
Now its cold to do work, unless I get access to indoors. The coolant stills seems to not to siphon coolant from the reservoir, and the level seems lower, and the heat not as great. I did end up cleaning the reservoir quickly, in the passed its been very dirty. For the heater core the top pipe is much hotter than the lower one, and the same for the radiator hose.
For the Victor Reinz gasket, does the notch part go face down?
please and Thank you everyone
