Thread: Temp gauge goes up when I give gas
Results 1 to 15 of 15
  1. #1 Temp gauge goes up when I give gas
    Sep 2012
    fort Wayne, in
    Ok so I'm driving home from work and I go to pass someone and from 50 to about 70 and let off the gas and I look down to see my temp gauge go up alittle and back down after a few seconds.I don't think this is normal so I check coolant levels and it looked fine to me. I get the low coolant light on when I first start the car for 3 or 4 seconds and I've put about half a bottle in and the level has seem to stayed. I checked the oil and nothing looks out of place. I'm going to get the car scanned tomorow to see if anything pops up but what should I look for? The car is due for an oil change anyway. Ideas?
  2. #2 Re: Temp gauge goes up when I give gas
    Antioch, IL
    More air+more fuel = hotter engine..........its fine
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Temp gauge goes up when I give gas
    Sep 2012
    fort Wayne, in
  4. #4 Re: Temp gauge goes up when I give gas
    Sep 2012
    fort Wayne, in
    I took a small video just wanna make sure it's good
  5. #5 Re: Temp gauge goes up when I give gas
    Antioch, IL
    us smart gp'ers dont do fb groups those are for morons
  6. #6 Re: Temp gauge goes up when I give gas
    Sep 2012
    fort Wayne, in
    Lmao! Well my lesson is being learmed right now because the guy on there is throwing some random **** and everything that could possibly be wrong! I appriciate the help man!
  7. #7 Re: Temp gauge goes up when I give gas
    Antioch, IL
    lol I wouldnt worry about it, to be clear we are talking like a line, maybe 2 and not 1/4 of the gauge correct?
  8. #8 Re: Temp gauge goes up when I give gas
    Sep 2012
    fort Wayne, in
    Yea it's right under the first big line then I give it gas and then it goes up to right past the big line so nothing huge and it comes right back down. Usually under heavier acceleration
  9. #9 Re: Temp gauge goes up when I give gas
    Antioch, IL
    A.O.K
    tell the fb people your engine blew up and the car torched down, then exit the group.
  10. #10 Re: Temp gauge goes up when I give gas
    GXP Level Member
    Mar 2015
    Tomball
    You mentioned that the coolant is disappearing and that you have a low coolant light. Wouldn't that tip you off that you are low on coolant? And the amount of movment you have is not normal. How many times did you say you have you added coolant?
  11. #11 Re: Temp gauge goes up when I give gas
    Sep 2012
    fort Wayne, in
    I don't think I said the coolant was going anywhere. The light came on but went off after a few seconds and only does it when I first start the car. Not when all the lights turn on normally. I check the fluid and it doesn't seem to be going anywhere and the level is pretty consistant. I've only added coolant one time and that was roughly about 3-4 weeks ago
  12. #12 Re: Temp gauge goes up when I give gas
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by buschegt View Post
    You can't go by that idiot light, the coolant level sensor is a known issue on these cars. They either don't work or work intermittently,pulling it and cleaning it or installing a new one is your best bet or just unplug it like others have.
  13. #13 Re: Temp gauge goes up when I give gas
    GXP Level Member
    Mar 2015
    Tomball
    "Now that's the weird part the light came on the other day so I put a half bottle in and refilled the overflow. The light only comes on for a few seconds and goes away but I check the level every time and only comes on when I first start the car"
    half lf a gallon of coolant and filling the overflow, but it's not low and it's not going anywhere.
  14. #14 Re: Temp gauge goes up when I give gas
    Sep 2012
    fort Wayne, in
    Didn't say it was low or that it needed it i just put some in there thinking that it needed it. But haven't had the light come on in about a week and it still goes up alittle. Someone said that maybe a week hose might be resricting flow?
  15. #15 Re: Temp gauge goes up when I give gas
    GXP Level Member
    Mar 2015
    Tomball
    But you stated that you put in half a gallon "Half a bottle", and you refilled the overflow. How would you be able to put in half a gallon into the radiator if it wasn't low? That quote was directly from your facebook post. I am the "Idiot" that gave you the things to check like the coolant elbows, LIM, overflow and so on related to the cooling system. The other guy mentioned that the lower radiator hose being weak and old could suck in and cause a restriction and I have seen this happen on other cars, especially older V8's with the spring inside that usually ends up falling apart and ending in the waterpump intake. You would see the hose collapse when the engine was warm enough that the thermostat was open and you revved the engine. People can only go on what you tell them and if you miss-worded your answer then we don't know we can't see it and we weren't there. You are our eyes and ears when troubleshooting over the internet.
    So if it's not low then look into that lower hose it should be firm and difficult to squeeze.
    Jeff
  1. Temp gauge problem after coolant temp sensor change.
    By Beast388 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2015, 08:00 PM
  2. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  3. Temp gauge..
    By Jordin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-29-2012, 09:48 PM
