Thread: 06 top end noise after crank sensor replacement
Results 1 to 13 of 13
  1. #1 06 top end noise after crank sensor replacement
    Aug 2016
    Ohio
    I have an 06 and just replaced the crank sensor, and now I have a serious top end noise as if a valve or two are bent. It has oil, just changed it Friday. I'm at a loss. Please help!
  2. #2 Re: 06 top end noise after crank sensor replacement
    Post a video.
    It's pretty much impossible for the motor to jump time through just doing a sensor replacement, so I doubt you bent a valve.
  3. #3 Re: 06 top end noise after crank sensor replacement
    Aug 2016
    Ohio
    I'm fixing to record it, but as I was loosening the bolt for the crank pulley the pulley spun since I'm a poor bastard and don't have an impact. Is it possible that they can be bent from that? I don't know Pontiac, I'm a VW and Ford guy.
  4. #4 Re: 06 top end noise after crank sensor replacement
    Nope, there is a timing chain behind the front cover that goes around the crank gear and cam gear. Both gears have timing dots, you could never make it jump timing from removal of the balancer.
  5. #5 Re: 06 top end noise after crank sensor replacement
    Aug 2016
    Ohio
  6. #6 Re: 06 top end noise after crank sensor replacement
    Hmm, it's not top end because valvetrain would make noise at half the speed of the crank.
    Sounds like something on the pulleys, maybe take the wheel off and see if you can hear the sound by the crank pulley. Only guessing but maybe something go bent on the back side of the balancer.
    And a side note my last name is Feucht too, pretty rare last name to see in the states.
  7. #7 Re: 06 top end noise after crank sensor replacement
    Aug 2016
    Ohio
    OK I'll check it out tomorrow and let you know. Gotta work at 5... And that is pretty weird with the last name. Are you from Ohio by chance?
  8. #8 Re: 06 top end noise after crank sensor replacement
    I am not, lived in minnesota all my life.
    Can't tell you how many people can't say it right, but that's almost a given with how it's spelled.
    Feist = Feucht, atleast how we say it.
  9. #9 Re: 06 top end noise after crank sensor replacement
    What was the condition of the balancer? If the rubber is cracked it can make noise.
  10. #10 Re: 06 top end noise after crank sensor replacement
    Aug 2016
    Ohio
    That's crazy that's exactly how we say it. But I feel hour pain bro I just gave up and tell people to pronounce it however they want to lol
  11. #11 Re: 06 top end noise after crank sensor replacement
    Aug 2016
    Ohio
    I honestly didn't check to see if it was. I will check tomorrow and let y'all know.
  12. #12 Re: 06 top end noise after crank sensor replacement
    Aug 2016
    Ohio
    OK sorry for the delay. The rubber is fine, but the key is all sorts of jacked up. So obviously I didn't pay attention that it was there. Anyway, I got a new key but now I can't get the old one out. Any ideas?
  13. #13 Re: 06 top end noise after crank sensor replacement
    St. Louis
    May be able to tap it out of the groove in the crank. Try and get under it with something small and pop it loose. Just don't gouge the crank or get into the crank seal. I had a feeling this was going to be another messed up woodruff key. Make sure the keyway in the balancer and the crank and free of burrs once you get everything apart. Then to reinstall just make sure it's lined up and push it on by hand, then tighten it up.
  1. 2004 GTP crank sensor
    By phil morris in forum 04+ Specifics
    Last Post: 06-22-2013, 05:26 PM
  2. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  3. Crank sensor and DIC issues
    By lucyboop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2011, 06:28 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
